Results 1 to 5 of 5
  1. #1 rmr 125 lacking power
    C-Moto Noob
    Jun 2012
    romsey
    hi.
    about a month ago i got a 10plate superbyke rmr 125, it runs fine starts piece of piss etc. But for some reason i can only seem to get 50-55 mph out of it, i know there not known for doing over 100 like say a cagiva mito or something but there should do at least 65-70 i mean come on its a 125 ffs, two of my mates have a sinnis apache and a pulse adreanline, and they just leave me and thiers are standard too (the sinnis has the exhaust of a classic mini copper on it) but the pulse is bog standard.
    (before i put it on the road i did a mini service replaced filters oil etc)
    i thought maybe my air filter has some crap in it so checked that and its fine. Been told i could do with a new chain and sprocket as mines seen better days (think she done a little bit more than the 2700miles it says she done) i have no idea how much of a difference that could make ( this is my first bike newbie much ) was wanting a new pipe for it one of those little yoshimura ones on ebay :D how much difference do they make? ( cant afford atm no job?? (N)
    Any suggestions will be brilliant!!
  2. #2 Re: rmr 125 lacking power
    C-Moto Guru
    Aug 2011
    texas
    need more info
    is your bike a 2 stroke or 4 ? when your reaching your "top speed" is the engine screaming at nearly top RPM's ?
    if its a 4 stroke I dont see much to be done to get more speed , a 2 stroke with a spocket change might drag another 15 mph out of it , but u will lose nearly all the bottom end "grunt"
  3. #3 Re: rmr 125 lacking power
    Dec 2008
    That bike is powered by 4-stroke Suzuki clone. Search spencer2004 's post for "mods".
  4. #4 Re: rmr 125 lacking power
    C-Moto Noob
    Oct 2012
    east lothian
    Quote Originally Posted by jay2012 View Post
    hi.
    hi jay dunno if this helps but ive got a rmr 125 aswell and shes got a yoshimura end can (around 35 ish quid for a copy off ebay) new cone air filter upgraded jets and shel do 70-75 with a head wind no problem and sounds pretty awesome doing it too sure its somewhere to start anyway hope this helps
  5. #5 Re: rmr 125 lacking power
    C-Moto Guru spencer2004's Avatar
    Jan 2012
    Norwich
    It could be something to do with the main jet; it could be blocked or you may need a bigger jet. If your carb and jetting is the same as the Pulse Adrenaline you will have a 97.5 jet, a 105 should be fine. You may also have crappy gearing for some reason, you could try a 16 tooth front sprocket and see how that goes.
    Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
  1. superbyke rmr need more power
    By goodst4r in forum Modifications (Cosmetic and Performance)
    Last Post: 07-28-2012, 01:04 PM
  2. power problems ?!?!?!?!?
    By relentless addict in forum Modifications (Cosmetic and Performance)
    Last Post: 09-25-2011, 08:04 PM
  3. Ideas for more power CQR 250
    By life in forum Modifications (Cosmetic and Performance)
    Last Post: 07-19-2010, 12:21 AM
  4. More Power from Jialing 250
    By zimanimal in forum Modifications (Cosmetic and Performance)
    Last Post: 09-29-2009, 12:47 AM
  5. Scooter Riders Power-Up...
    By CrazyCarl in forum Scooter
    Last Post: 03-10-2009, 12:39 PM
Tags for this Thread
View Tag Cloud
