Thread: High RPM when starting
#1 High RPM when starting
- Jan 2013
- Walton on the naze
01-28-2013, 04:30 PMHi there i have a sinnis apache 125 58 plate. When i start it from cold within 30 seconds the bike starts to run at 4-5000 rpm. I was wondering if anyone could help me with this problem. I have tried playing with the idle screw but this does not make a change. I need to get it fixed before it starts to break my camshaft and cylinder head.
Thank You
#2 Re: High RPM when starting01-28-2013, 06:39 PM
Check your carb.
#3 Re: High RPM when starting
- Jan 2013
01-30-2013, 04:30 PMHi there mate thanks for reply. Cleaned the carb and still no change. Do you have any other ideas. All ideas will be much appreciated.
#4 Re: High RPM when starting01-30-2013, 06:38 PM
Maybe check the cylinder head and the gasket? If it sucks air from the gap of the cylinder head, then that kind of thing could happen.
Other than that, are you completely sure you have your carb well adjusted?
In theory your engine is getting too much air from somewhere, and it will kill the engine if you don't fix it.
2010 Qlink XF200 loss of power (fuel tank vacuum) at high rpm, wide open throttle
By lakeclark in forum MaintenanceReplies: 6Last Post: 08-13-2011, 07:03 PM -
High Praise for Scooterdepot's Service
By BellaCorse in forum StreetReplies: 2Last Post: 07-14-2011, 04:45 PM -
Stalling high rpm qingqi 200gy
By dacru in forum MaintenanceReplies: 7Last Post: 04-13-2010, 05:44 PM -
YouTube High Quality Videos..EASY!
By CrazyCarl in forum Ride, Record, CreateReplies: 1Last Post: 02-01-2009, 12:37 AM -
What is HDR? High Dynamic Range Photography
By Supersignet in forum Ride, Record, CreateReplies: 1Last Post: 05-02-2008, 12:11 AM
