Thread: Sinnis Aoache 125 idle help
#1 Sinnis Aoache 125 idle help
- Jan 2013
- Walton on the naze
01-28-2013, 04:32 PMHi there i am stuck and need help with my 125. When i start the bike it revs really high between 3-5000 rpm. When i try and put the choke down the bike slowly cuts out. Looked at the carb and i couldn't actually see the idle screw. Its probably there but i don't wanna start playing with screws that could be important. If someone could help me that want be great and would be much appreciated. By the way my apache is a 58 plate if that makes any difference.
#2 Re: Sinnis Aoache 125 idle help
02-03-2013, 10:53 AMDear Bradley,
You get any help with this? I seem to remember someone asking a very similar question a week or two ago, and getting some decent advice. Might have been the RMR Superbyke, which I think is a clone of your Sinnis, or vice versa. Like try this thread for starters.
cheersjkp
#3 Re: Sinnis Aoache 125 idle help
- Sofia, Bulgaria
02-03-2013, 11:11 AMJust a few threads below yours:
http://www.mychinamoto.com/forums/sh...085-Air-Intake
http://www.mychinamoto.com/forums/sh...-when-starting
#4 Re: Sinnis Aoache 125 idle help
02-03-2013, 06:02 PMMake sure you have some free play in the throttle, if you dont then adjust it using the adjuster which should be located near the throttle possible covered by a rubber sheath. If that dosen't sort the problem then you can adjust the idle speed using the screw on the side of your carb (not the bottom).
#5 Re: Sinnis Aoache 125 idle help
- Jan 2013
02-12-2013, 04:44 PMThanks to everyone who has helped. Much appreciated.
- Jan 2013
- Manchester UK
#7 Re: Sinnis Aoache 125 idle help
- Jan 2013
04-18-2013, 03:02 PMHI there mate sorry its been a while but it still hasnt been fixed. Any other ideas?
Sinnis apache 125 Idle help.
By Bradleyrayner in forum Test TrackReplies: 3Last Post: 01-27-2013, 12:34 PM -
strange stalling at idle issue.
By palisadeguy in forum MaintenanceReplies: 8Last Post: 03-25-2012, 05:14 PM -
Sinnis Apache 125 /RMR 125 Superbyke lack power above idle
By s91s91 in forum MaintenanceReplies: 0Last Post: 09-17-2011, 05:38 PM -
throttle sometimes locked and bad idle....
By txm123 in forum MaintenanceReplies: 1Last Post: 11-21-2009, 04:36 AM -
QM200GY idle problem, valve clearances.
By forchetto in forum MaintenanceReplies: 20Last Post: 08-14-2008, 01:06 AM
