#1 Bike Not starting with Electric starter.
- Mar 2013
- Vancouver
03-17-2013, 04:19 AMHey guy's ! I'm not mechanically incline but ill try to explain my problem.
Bike run no.1 with foot crank but doesn't want to start with E-start.
Solenoid doesn't click when i press the starter.
1st. Ive put 12v on the 2 cable and it does click.
2. ignition switch has 12v to it.
3. Ignition switch pass continuity test when pressed.
4. 12v up to the solenoid when ignition switch is pressed.
Ive bridge the solenoid on the 2 small wire and connected 12v to those 2 wire and the bike start.
I'm kid of lost at this point.
Also, I'm not sure what is the green wire that connect to the solenoid.Yellow/Red is 12v from starter but the other one is a mastery for me... Is it for the kill switch or clutch depress switch?
Looking forward to your input.
Samuel
#2 Re: Bike Not starting with Electric starter.
03-17-2013, 04:34 PMTry bypassing the safety switches and see if that helps, you should have one on the clutch lever and one on the side stand. To bypass them you may have to either remove the wires from the switches or short the wires with another bit or wire.
Also which model of bike is it?Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#3 Re: Bike Not starting with Electric starter.
- Mar 2013
- Vancouver
03-17-2013, 09:19 PMIf y bypass the green wire (assuming it's the neutral safety switch) by connecting it directly to the battery (-) it does start with starter switch.
By doing so , could i break something? IE having current to the solenoid vs only when it's in neutral?
Is work's for now i guess ;)
But i'm a bit scared haha.
Thanks for your help!
Edit: I have a Konker KPX 250.Last edited by Sampep; 03-18-2013 at 02:00 AM.
When starting the bike it runs at 4-5000 RPM
By Bradleyrayner in forum Test TrackReplies: 6Last Post: 04-19-2013, 07:27 AM -
Sweet electric concept bike
By felix in forum Industry News and Moto TalkReplies: 9Last Post: 05-24-2012, 09:01 AM -
Energica – All Electric Sports Bike Announced By CRP
By bikerdoc in forum Industry News and Moto TalkReplies: 0Last Post: 11-18-2011, 12:43 AM -
For Sale Brand New Honda Wave Dash 110 (Electric Starter)...RM3500
By zainal2011 in forum Industry News and Moto TalkReplies: 0Last Post: 07-01-2011, 02:39 AM
A Working VPN Solution?
