Page 45 of 47 FirstFirst ... 25354344454647 LastLast
Results 441 to 450 of 463
  1. #441 Re: Shineray / XinYuan X5 review
    Senior C-Moto Guru
    Apr 2011
    Taizhou, Zhejiang
    So I have discovered that my fuel tap isnt working the hard way yesterday.....
    Got a front puncture and obviously there is no center stand so the easiest option was to lay the bike on a side and work on the wheel. The fuel started dripping through the carb breather hose so i close that off. Then it started leaking a substantial amount through the airbox and air filter. Not only it was dangerous but also wouldnt let me fix my flat.
    Fortunately I was with my mate so he helped me balance the bike on some rocks
    Is this faulty tap a reason for missing fuel? I didnt ride my bike for about 2-3months in the summer and when I finally did I have noticed that the consumption was about 40% higher. I think the petrol might have just evaporated through the carb
  2. #442 Re: Shineray / XinYuan X5 review
    Life Is Good! ChinaV's Avatar
    May 2008
    Guangdong, China
    That doesn't make sense because the floats and needle should stop the passing of fuel. I would look at the petcock, floats, & needle. replacing all 3 should be less than 100 RMB. Shitty China gas could have caused problems.
    I would be more worried about the gas that didn't come out of the airbox and headed into your cylinder via the intake valves.
  3. #443 Re: Shineray / XinYuan X5 review
    Senior C-Moto Guru
    Apr 2011
    Taizhou, Zhejiang
    Well, after the whole thing the bike starter and ran fine. I will replace the petcock and check the float and needle. And will replace the oil as it prolly has fuel in it, although I just did that 500km ago
  4. #444 Re: Shineray / XinYuan X5 review
    Senior C-Moto Guru
    Apr 2011
    Taizhou, Zhejiang
    Does anyone know whether the front sprocket (most likely according to taobao) of Honda Xr400 will fit the X5?
    More importantly
    Will xr400 wheel bearings fit the X5?
    Im going to Europe soon and could buy some parts. Sprocket I can measure but the bearings require a bit more precision
  5. #445 Re: Shineray / XinYuan X5 review
    KING of MCM LOL prince666's Avatar
    Apr 2012
    china (Longkou), Hainan
    My advice would take the bits of the X5 with you back to the EU and then match them up.
    "Arguing on the Internet is like running in the Special Olympics, even if you win you're still retarded"
  6. #446 Re: Shineray / XinYuan X5 review
    Senior C-Moto Guru
    Apr 2011
    Taizhou, Zhejiang
    I thought about it but wanted to avoid taking the bearings out.
    If I cant confirm the size I prolly will though
  7. #447 Re: Shineray / XinYuan X5 review
    Apr 2012
    10 mins job and you will make sure you get the correct one.
    Also, most good makes are marked with the inner and outer size in mm.?
    motor maniac ShuBen's Avatar
    Jul 2010
    Beijing
    Quote Originally Posted by prince666 View Post
    Also most good makes are marked with the inner and outer size in mm.?
    Just take the wheels out. Remove the dust cover ring and read the bearing number and brand on the out bearing ring. The numbers are something like 6605 ...
    Then put dust cover ring in assemble wheel. Story done.
    Anyway I would not carry that stuff from Europe. Bearings you can find from industry supplier in China -> FAG, NSK, etc.
    I bought all engine and wheel bearings for my X2 in good quality in China.
    SWM RS500R, R1200GS LC
    Jul 2010
    Beijing
    Quote Originally Posted by ShuBen View Post
    Oh, ... And ifvyiu can only find sealed bearing (normally with Z at the end) just use a little screwdriver and remove the seal ring gently. Then you have a normal bearing :-)
  10. #450 Re: Shineray / XinYuan X5 review
    C-Moto Regular
    Feb 2016
    Xining
    yup, easiest way to check bearings - see marking on bearing, exactly as Shuben said.
    for sprockets I could advise to check this link and see whether Honda XR400 sprockets size match dimensions of Shineray's
    http://www.jtsprockets.com/catalogue/model/877/
    maybe you even don't need to take off X5 sprocket, just check some links on taobao, where seller show sprocket dimensions and then compare them to dimensions from link above.
  1. Review of the Yamaha YBR 125
    By Lao Jia Hou in forum Street
    Last Post: 12-01-2013, 08:47 PM
  2. My Review of the CFMOTO 650NK
    By Topmanda in forum Street
    Last Post: 09-24-2013, 12:59 PM
  3. Galaxy XTR 250 review
    By felix in forum Dirt n' Dual-Sport
    Last Post: 09-14-2013, 05:35 PM
  4. DB200B / SHINERAY GY7 Canadian review
    By kens in forum Dirt n' Dual-Sport
    Last Post: 05-15-2012, 04:26 PM
  5. Galaxy XTR 250 Review
    By Andy Hird in forum Dirt n' Dual-Sport
    Last Post: 12-13-2010, 01:01 PM
Tags for this Thread
View Tag Cloud
