Thread: rear brake bleeding
Results 1 to 9 of 9
#1 rear brake bleeding04-21-2013, 06:27 PM
hi can any one help me .I cannot bleed my rear brake on pulse adrenaline I keep pressing and closing nipple but nothing I have been doing it for 4 hours and no different ..
#2 Re: rear brake bleeding
- Sofia, Bulgaria
04-22-2013, 06:03 AMIf nothing else helps, detach the brake caliper from the swingarm, and hang it somewhere so that the bleeding "nipple" is the highest point in the system.
#3 Re: rear brake bleeding04-22-2013, 06:46 AM
#1 Fill the master cylinder.
#2 Attach a piece of (clear) fuel line to the brake bleeder.
#3 Suck the brake fluid through with a cheap syringe, or carefully do it by mouth without sucking up brake fluid.
#4 Once the fluid shows up in the fuel line, you can probably prime the system by pumping the brake with the bleeder closed and then quickly cracking the bleeder to let the air bubbles escape.
#4 Re: rear brake bleeding04-22-2013, 09:31 AM
sucking on any part of a brake system is a very bad idea
brake fluid is not oil its a freaking nasty chemical and it will make strange things grow in your throat.
use a syringe, any friendly junkie can show you how to keep the air out of it
#5 Re: rear brake bleeding
#6 Re: rear brake bleeding04-22-2013, 11:13 AM
I'm pretty sure it's raining brake fluid right now in xi'an.
#7 Re: rear brake bleeding
#8 Re: rear brake bleeding04-22-2013, 11:47 PM
You say fluid is comeing out! If its comeing out of your rear mastercylinder (near your brake pedal) then a seal has gone in cylinder.
If not reverse bleeding with oral type syringe is best & move caliper high or brake cylinder at angle to make air come to top.Play fast die last
#9 Re: rear brake bleeding
Brake master cylinder not pumping ......... Why ?
By Sprocket in forum MaintenanceReplies: 2Last Post: 03-13-2013, 07:15 AM -
Changing brake oil hose?
By slabo in forum MaintenanceReplies: 1Last Post: 05-23-2010, 05:45 AM -
Brake rubber bits ?
By Sprocket in forum Parts DeskReplies: 4Last Post: 02-21-2010, 08:37 AM -
Rear Brake Master Cylinder parts
By txm123 in forum MaintenanceReplies: 11Last Post: 11-23-2009, 03:50 AM -
Brake shoes replacement
By txm123 in forum MaintenanceReplies: 1Last Post: 08-17-2009, 02:38 PM
комедии 2024 онлайн...
