Thread: Lexmoto xtr service help
#1 Lexmoto xtr service help
- Aug 2013
- Liverpool
08-16-2013, 01:44 PMCould anyone help us in the right direction? I've just purchased this bike on 11 plate as a first bike but it seems to idle at very low revs and will cut out at lights if I don't give it a little power I heard that it is a cbr replica would the cbr service manual be useful for this bike? Any input would be appreciated thanks
08-17-2013, 07:56 AM
That's carbureted, isn't it? I'd bring it to the shop for a check on the carb and idle. Or try flushing the carb and installing an inline fuel filter. Maybe you got some gunk in the tank or bad gas and the main jet is clogged up.
#3 Re: Lexmoto xtr service help
- Aug 2013
- Liverpool
08-17-2013, 10:25 AMThanks for that I thought it might be a carb problem and guy I bought it from did say it had been sitting for 8 months unused so could be clogged jet as you said do you no if they would sort that during service? as I'm booked in for 1 in a few days
08-17-2013, 11:01 AM
I doubt they'd do it if you don't ask them. It's not too tough, but a bit of a hassle. If its been sitting, for sure try that. I'd also ask them to put in an inline fuel filter if there's not one there.
#5 Re: Lexmoto xtr service help
08-20-2013, 08:40 PMOn the right hand side of the carb there is a screw, with the engine warmed up fully and idling turn the screw clockwise until the idle is at the correct speed of around 1500 RPM.
Failing that adjust the idle mixture screw on the bottom of the carb to achieve the best idle then re-adjust idle to 1500 if necessary.
Failing that remove the carb from the engine, take the bottom place off and clean out everything you can.
Failing that get a new carb they are only cheap ;)
http://www.ebay.co.uk/itm/Carb-NEW-C...item3ccc6ba7c1Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
Raising my Lexmoto lsm
By speedyspeedyboy in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 02-27-2013, 10:35 PM -
end can for lexmoto xtrs 125
By xtrs125 in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 02-19-2013, 10:46 AM -
Lexmoto LSM 125 service
By Lowi in forum MaintenanceReplies: 9Last Post: 02-03-2013, 10:04 AM -
Lexmoto LSM 125
By Sketch in forum Ride Prep and Making TracksReplies: 12Last Post: 08-15-2012, 08:30 PM -
Lexmoto LSM 50
By luke_hayden in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 06-24-2012, 03:37 PM
