Results 1 to 9 of 9
  1. #1 new levers for cfmoto 650nk
    C-Moto Not-so-Noob
    Sep 2013
    adelaide
    Just another change to my cfmoto 650nk cnc alloy levers needed a bit of work for them to fit but they do work well. have yet to change the mirrors to something better. I did have endure mirrors attached to handle bars but couldn't see any thing behind me
    alex
  2. #2 Re: new levers for cfmoto 650nk
    C-Moto Noob
    Nov 2013
    Australia
    Hey Pommie,
    Bars and levers look good! What levers did you start off with? Also, does the little 6 position selector switch still work after the modifications?
    I think I may have seen your bike on the CFMOTO Aus facey page - looks very cool.
    Any info would be greatly appreciated :D
    Zach
  3. #3 Re: new levers for cfmoto 650nk
    C-Moto Senior
    Jun 2013
    Hanoi, Vietnam
    I can confirm that levers from 07-08 Er6 will fit CF650, 09-11 will fit 50%.
    Clutch lever is the same on all ER6 models up to 2011, but brake lever is different from 2009 onwards, so it would need some modification to get it to work.
  4. #4 Re: new levers for cfmoto 650nk
    C-Moto Not-so-Noob
    Sep 2013
    adelaide
    hi zach.
    the levers are for a 06 er6n and you need to file down some of the lever bolt hole as its to wide (about 2-3mm) also had to drill and tap a new thread and fit a cut down bolt for the brake master to work...as for the 6 postion selector still works without any issues, the clutch is on 2, brake on 6 as i like the brake lever close as i use 2 fingers for brake control.
    As for CFMOTO facebook yes its my bike.
    alex
    Quote Originally Posted by Zach View Post
    Hey Pommie,
    Zach
  5. #5 Re: new levers for cfmoto 650nk
    C-Moto Senior
    Jun 2013
    Hanoi, Vietnam
    Quote Originally Posted by pommie View Post
    hi zach.
    alex
    I must say that if you had to drill and tap brake lever it was not from 06 but 09 :) as that was the year when Kawasaki decided to change the design.Screen Shot 2013-12-22 at 20.53.28 .jpg
    here is picture from 06 kawasaki parts diagram and as you can see its identical to CF650
    here is the original brake lever from kawasaki Er6 06-08 model.
    Here is Er6 2009 onwards brake lever.
  6. #6 Re: new levers for cfmoto 650nk
    C-Moto Not-so-Noob
    Sep 2013
    adelaide
    ok the levers I used are for a er6n 06 onwards, as this is the era cfmoto used for the design of this bike as for my brake lever and adding the bolt its so the brake switch will work. also ive added bar end mirrors as the massive cow horns on the bike are just shocking. not sure about anyone else but I could never see anything behind me due to the bad vibration or should I say badly made mirrors...also a digital clock only for the fact cfmoto forgot to add it into the cluster display (again ebay special)
  7. #7 Re: new levers for cfmoto 650nk
    C-Moto Senior
    Jun 2013
    Hanoi, Vietnam
    I was thinking Rizoma reverse classic mirrors.. but they are quite expensive so i think i just go for fake ones. Bike is made in China so why not mirrors too ;)
    So you added bolt to hit the clutch master cylinder? that's because from 2006-2008 it was level and clutch lever had dimple to press it, but from 2009 onwards Kawasaki changed design and now clutch master cylinder had a shaft with ball end to mate it to clutch lever. i also seen adds what say kawasaki Er6 clutch lever 2006-2011 but its not correct.
    i also did same mod to my lever.
  8. #8 Re: new levers for cfmoto 650nk
    C-Moto Noob
    Mar 2015
    gold coast
    I can confirm also the Kawasaki ER 6N '06' adjustable clutch lever is the same for the 2013 650NK. However, the same can't be said about the brake lever for the same model.
    Attachment 20177Attachment 20176
    My clutch pinged apart and took ages to find a replacement. Was held together with duct tape for a while...
    The brake lever unfortunately did not fit. The part was too wide to fit into the bracket.
    Before I bought the Kawasaki levers, I had bought some shorty levers on ebay. They were looking like they were not being delivered, so that's when I purchased the K levers from wemoto.com.au
    Then, the ebay levers arrived. I was glad because I had one black lever and one chrome lever on my bike due to the ill fitting Kawasaki brake lever.
    Anyway, the ebay clutch lever fit perfectly, probably better than the original with less give, but the brake lever needed a little adjusting for them to fit. I had to file down both the body of the lever where the bolt goes through, and had to file down the extra bit of metal where the brake light switch is held in. These few minor adjustments allowed the lever to fit perfectly.
    I like how the shorty's look in the end.
    If anyone knows of a better fitting brake lever from another brand that will just perfectly fit the 2013 650NK, feel free to let me know. Otherwise, the K clutch lever does fit but as far as I can tell, it only comes in black if you need the adjuster.
  9. #9 Re: new levers for cfmoto 650nk
    C-Moto Noob
    Mar 2015
    gold coast
    Not sure why some photo's didn't work. here they are -
  1. My blog of a WK650i / CFmoto 650NK
    By WirralGhostHunter in forum Street
    Last Post: 05-11-2014, 02:40 PM
  2. New CFMoto 650NK blog x2
    By ZMC888 in forum Street
    Last Post: 03-29-2014, 06:38 AM
  3. My Review of the CFMOTO 650NK
    By Topmanda in forum Street
    Last Post: 09-24-2013, 12:59 PM
  4. Used CFMoto 650NK for sale in Shanghai
    By bikerdoc in forum Bike Market - Classifieds
    Last Post: 08-19-2013, 04:05 PM
  5. CFMoto 650NK sport bike
    By Lao Jia Hou in forum Street
    Last Post: 08-28-2012, 04:23 AM
