Results 1 to 10 of 15
#1 Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston kit03-29-2011, 03:11 PM
Is "Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston kit and gasket" kit available in China from say taobao.
I can't seem to get answers from http://www.chinese-parts-canada.com/...bore_kits.htmlVince
#2 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 12:22 PM
I think it is already a bored out CG125, the CG125 does not have a cam chain or cam bearing to wear out so and the internal part of Honda engine are in families so they share, the engine is a CG125 with what a piston from a CB550? CB750? I never bothered to get that into it. But because it is a OHV they pushed it way up in displacement the other engines like the 163FML is the same as the CMX200 not bored out. The OHC share more with the CB side of the Honda engine family like the CRF230 or FTR223. Not clones but closer to the original designs.
It may already have a CB550 cylinder in it? Because the CG125 is such a work horse it can be bored out, and many do it including the Chinese manufacturers.
#3 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 01:39 PM
MJH,
I'm asking for a 70mm kit( cylinder and piston) for my 67mm bore 167FMM from a Chinese source. I know this engine is based on a Honda CG125. The Canadian source doesn't seem to be available as all I get from them is an automated reply thanking me for my email.
How can I make this any clearer for you??????Vince
#4 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston
#5 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 02:20 PM
MJH,
Thanks but that is the same company that just sends me automated responses.Vince
#6 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 02:29 PM
It’s not really a CG125 it some sort of Chinese manifestation, the CG stroke is 50mm. It’s obvious looking at the engine it does not have much mass to it, boring it out would likely make the cylinder walls too thin. Likely overheat and loose compression. So why not attempt to change the induction first then leave that 70mm cylinder for a fix if it also overheats and burns up the rings. Which it will likely do anyway.
#7 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 02:43 PM
I like that site...to bad they are not responsive.
#8 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston03-31-2011, 03:08 PM
MJH,
Just curious but do you actually have a motorcycle?Vince
#9 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston
- Apr 2011
- Bergen County, NJ
04-12-2011, 05:03 PMCurious about this mod myself Barnone or any other possible performance upgrades. Is this the same motor that is in your DF Bobber and the Heist correct? Admittedly I don't know crap about these Chinese motors, just trying to figure out what can be done with this 250.
Trying to find any good info on these motors is like finding a needle in a haystack, the same names keep popping up on different forums. I could tell you everything about an HD motor but trying to find good info and reliable sources on these motors is so vague.
#10 Re: Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston04-12-2011, 05:40 PM
JK3,
It is the same engine as in the DF and Heist and is actually 229cc and not 250cc engine like CCW and others claim in their advertisements.
Probably not worth the expense or trouble going to a 70mm bore to get it out to about 250cc. I'm looking for a 400 to 600cc air cooled single that will fit in the frame.Vince
Pulse Adrenaline 150 big bore Kit
By superfamous in forum Modifications (Cosmetic and Performance)Replies: 19Last Post: 08-04-2021, 08:24 AM -
Bore kit qingqi 200
By ceron in forum MaintenanceReplies: 6Last Post: 11-29-2010, 11:32 PM -
Suzuki/Qingiqi big bore kit for 125cc?
By k44rll in forum Parts DeskReplies: 29Last Post: 07-02-2010, 01:02 AM -
mikilon 125 sb m 96 ? big bore kit help
By erkfreak in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 05-06-2010, 10:21 AM -
YBR 125 bore kit
By Jmarc in forum Modifications (Cosmetic and Performance)Replies: 7Last Post: 03-18-2010, 05:58 PM
Get vivid impressions and...
