Thread: Chinese engine identification
Results 41 to 50 of 50
#41 Re: Chinese engine identification
#42 Re: Chinese engine identification
#43 Re: Chinese engine identification
- Nov 2015
- Weston
11-17-2015, 07:59 AMHere is the engine, barrel, piston and gudgeon
#44 Re: Chinese engine identification12-01-2015, 07:34 AM
Тhere is something wrong with that engine.
Right crankcase cover is typical for "small bore" horizontals, electric starter too. But cylinder confused me. OK, it is 54 mm bore, but generally, this bore you can not see on "small bore" horizontals because spacing between cylinder studs does not allow that.
Also, there is issue with stroke, because shaft that propels oil pump is so close to crank cheeks...
But, what you need is to fix this engine and make few spins with your pit bike. If only piston was issue, I believe that MHJ's link will be useful to you.Ask me nothing - I DO NOT speak english. Really...
#45 Re: Chinese engine identification
- Dec 2015
- knob noster
12-08-2015, 08:22 PMI just bought a DJ152fmh pit bike and have no information on how/where to get parts or what will fit
#46 Re: Chinese engine identification12-09-2015, 12:37 AM
#1 rule owning "china machine" --- WYSiWYG. Find via picture that matches ALL the measurements.
DJ(Many "Ducar" use that...) | 52(nearest bore) | H: 110
http://item.taobao.com/item.htm?id=36141623524 may gives the idea.
#47 Re: Chinese engine identification
- Dec 2015
- knob noster
12-09-2015, 12:48 AMI need a new electric start cover and base plate where can I find the parts? It's a under engine electric start. Both cover and base plate have metal broke off
#48 Re: Chinese engine identification
- Jul 2016
- Asia /Pakistan
07-15-2016, 09:12 AMhi
i have engine supposidely 125cc
it is DJ1P54FMI
where can i find its spec ?
bore storoke ? CR ? Engine Oil Level (currenlty i poured 0.7L as the it gave the reading in the top range of dipstick) ? type of carb suitable for it ? (currently using pz22 with 32 pj and 85mj c clip is at the top to richen mixture).
what could be inlet/exhaust valve clearance ?
what are its gear ratios ?
what is its stator specs ? how many watts it puts in each coil ? (it has 6 coil stator that is 83mm at the largest dia)
is it full wave or half wave ?
i bought the engine on as it is condition and installed in my bike which had initially jh90 type of engine.
#49 Re: Chinese engine identification
- Aug 2021
- Estonia
08-17-2021, 01:37 PMBased on the information on this thread, I made a quick little tool:
https://dmonizer.github.io/chinamotors/
#50 Re: Chinese engine identification
- Apr 2023
- Wv
04-11-2023, 06:50 AMMy engine serial number is vz016103. What is vz for I can't find it any where
