Thread: Jet size help
Results 1 to 7 of 7
#1 Jet size help
- Jan 2013
- Walton on the naze
06-04-2014, 03:45 PMHI there i have a apache 125. Its got a sports exhaust on it aswell as a cone filter. I was wondering if anyone knows what size jet i should running it on with these little mods. I was running a 98 but the bike didnt want to run aswell as it should. So ive just brought a 105 and still cant it running right but need to spend more time on it. Any advice would be greatly appreciated. Thanks
#2 Re: Jet size help
- Sep 2011
- Sofia, Bulgaria
06-05-2014, 03:54 AMDid you also rise the needle too?
#3 Re: Jet size help
- Jan 2013
06-05-2014, 08:54 AMAh no I didint. How do you do that. And thanks for reply mate
#4 Re: Jet size help
- May 2014
- New zealand
06-05-2014, 09:55 AMsmall washers 1mm and keep starting and checking after each one to see how it runs some bikes have clips to raise them depending on carby.
youtube carby needle mods theres a few on there.
#5 Re: Jet size help
- Sep 2011
- Sofia, Bulgaria
06-05-2014, 10:00 AMCheck this video for example (your carburetor is probably more like the second one they show):
In your case you'd most probably need more rich mixture, so put the clip on the lowest position and see if gets better. If not, you might need a bigger main/slow jet. Or a leaner mixture.
Keep in mind that needle position affects mainly throttle response.
#6 Re: Jet size help
- Jan 2013
06-05-2014, 01:02 PMthe bike is getting to 6-8000 rpm and then it stutters. Ive tried making the mixture more rich and lean but doesnt help at all/ Any clue
#7 Re: Jet size help06-05-2014, 03:42 PM
The idle jet adjust screw only does idle. The main jet only does the main torque mid range powerband so you need to lift the needle a few mms to let in more fuel for the bike to run rich enough at high revs if your carb is a needle type.
Put in a new spark plug, run the bike at 8000 rpm and then hit the kill switch, pull the plug out if it's whiteish on the electrode it's running too lean. Probably why it's stuttering too lean at high rpms.
Hope this helps!
253FMM Jet Size
By Acsww4 in forum Modifications (Cosmetic and Performance)Replies: 0Last Post: 09-15-2013, 12:39 PM -
650nk Radiator grill size?
By Wald0 in forum StreetReplies: 1Last Post: 09-05-2013, 02:58 AM -
Can I fit rear tyre of size 150/70-14 in my jetmax?
By karimfadl in forum Modifications (Cosmetic and Performance)Replies: 8Last Post: 07-03-2013, 11:30 PM -
Carb Pilot size advice
By arancara in forum Modifications (Cosmetic and Performance)Replies: 13Last Post: 04-04-2013, 07:39 AM -
what size glass fuse to use
By stacyc72110 in forum Parts DeskReplies: 2Last Post: 01-17-2013, 09:40 PM
