Thread: CF650G
Results 1 to 1 of 1
  1. #1 Moto CF650G ABS Police MC
    foreign China moto dude bikerdoc's Avatar
    Oct 2009
    Zhejiang PRC, OZ, NZ
    CF650G ABS police motorcycle by CFMoto.
    Can't upload photos to this section so have started a new thread with photos here
    Specifications:
    • Wheelbase: 1415mm
    • Seat height: 780-810mm (adjustable cushion/air-bag 30mm)
    • Minimum ground clearance: 140mm
    • Curb weight: 265kg
    • In-line 2 cylinder, 4 valves/cylinder 4 stroke, liquid cooled engine
    • 52kW@8750rpm
    • Bore x Stroke: 83.0 X 60.0mm
    • Compression ratio 11.3:1
    • Displacement: 650cc
    • Transmission: 6-speed manual
    • Steering head angle: 32°
    • Clutch: Wet multi-plate
    • Fuelling: BOSCH EFI
    • Front tyre: 120/70 ZR17
    • Rear tyre: 180/55 ZR17
    • LED lighting (headlight/tailight)
    • LED indicators (turn signals) redesigned from the 650TR/TK
    • Headlight side by side (include a pair of projector lenses)
    • Electric adjustable screen (range over 100mm) with position memory
    • ABS (though the brake calipers are still the JiJuan brand as found on the 650NK/TR/TK)
    • Ø43mm inverted shock absorbers with adjustable preload and dampening
    • Air inflatable adjustable seat (range of 30mm) with what looks to be a more upright (comfortable) riders position.
    • Instrument panel, has separate dial tachometer and speedometer, with LCD odometer, trip meter and clock, but no gear indicator
    • Integrated luggage
    http://cfmoto.com/NewsCenter/Detail.aspx?id=231
    Learn the rules like a pro, so you can break them like an artist
    - Pablo Picasso
