Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1 Bigger engine for my GY200 Qingqi
    C-Moto Noob
    Apr 2009
    I have a 200cc QY which I travel 64km to work with everyday. I have managed to get it to about 130kmh but that is it! Does anybody have advice on what larger motor I can put in to make it faster and stronger. Does Qingqi make a 400cc and would it fit?
    If not what else can I do to get more hp and speed out of my 200?
    Apr 2008
    NoVA
    Tinod,
    Currently QingQi does not make a larger engine that will simply snap into thte frame. A 400cc motor would be too big for the frame and there is a question if the frame would be strong enough. They do make a 250cc motor but it's not afor sale yet and the factory says it's not a direct bolt on replacement (meaning you must modify the frame a little) to make it fit.
    We hope to have more news on that engine here soon.
    Without swapping the engine, you other options are new exhaust pipe (which also makes it lighter) and some jet changes in the carb. Search around on MCM and you'll find some great articles on both of these mods!
    Senior C-Moto Guru ZMC888's Avatar
    Oct 2008
    Zibo, Shandong - Sometimes SW England
    Hopefully we will test the 250cc engine soon, and we will ask the Qinqi engineers how a 200cc bike ca be upgraded to 250cc, and if it is safe and possible to do so. I'm sure that Qingqi would be happy to supply 250cc engines if a 200cc Qingqi bike can be upgraded safely and legally.
    Apr 2008
    NoVA
    The 250 engine requires some engine mount modifications to work correctly. Not sure how easy an upgrade would be.
    C
    C-Moto Regular Luis Carlos's Avatar
    Nov 2008
    Quote Originally Posted by tinod View Post
    Sundown 200cc STX motard
    C-Moto Regular
    Oct 2008
    Stafford, Texas USA
    Is that a freakin TURBO? More pics please!!!
    Qlink XF200 Flat Black MODS: P&P Exhaust Pipe-125 Main Jet-35 Idle Jet-Jet Needle Clip On Forth From Top Position-Denso Iridium Spark Plug IX24-Sprocket Specialists #550-16 16T Front Sprocket-SAI Removed-Rear Fender Cut Off-Brake Light Flasher-55 Watt Headlight Bulb
    Nov 2008
    This pic belongs to a former forun supermotojunkie the link is this
    http://www.supermotojunkie.com/showthread.php?t=80822
  8. #8 fazer 250 45cv "ybr250"
    Nov 2008
