Thread: Starter removal?
Results 1 to 6 of 6
#1 Starter removal?
- Jun 2015
- Canada
06-15-2015, 07:19 PMOK, so my grandson's quad has a Honda 110 cc engine. when I press the start button the solenoid comes in and I have power through to the starter but the starter doesn't spin. After playing with it a few times I did get it to turn over once for a few seconds until I realized there was no gas in the tank so I filled it and tried again but, once again it would not crank. I removed the two screws holding the starter to the block but the starter motor will not pull free. It backed off about 1/4 " but seems to be hanging up on something inside - is there a trick to this?
#2 Re: Starter removal?06-15-2015, 08:20 PM
There is no solenoid/bendix on that engine, just chain that connects starter and freewheel on the crankcase.
Ask me nothing - I DO NOT speak english. Really...
#3 Re: Starter removal?
- Jun 2015
- Canada
06-15-2015, 10:53 PMThere is a little solenoid that runs the starter but it hangs under the front body. I guess the chain is what's holding the starter in place. How is that accessed? There must be a cover that comes off I guess.
#4 Re: Starter removal?06-16-2015, 04:04 AM
You must to remove left crankcase cover and you'll reach C-clip that holds starter's sprocket, and after that you'll figure it out by yourself.
#5 Re: Starter removal?
#6 Re: Starter removal?06-18-2015, 05:18 PM
Don't thank me in advance - job's not finished.
lexmoto lsm 125 so annoyed with myself non starter now!
By kieronh84 in forum MaintenanceReplies: 4Last Post: 06-06-2013, 11:10 PM -
Superbyke RMR200 starter clutch
By ghostrider in forum MaintenanceReplies: 3Last Post: 07-09-2011, 03:27 PM -
125 flywheel removal
By 50dude in forum MaintenanceReplies: 1Last Post: 05-06-2011, 01:10 PM -
starter solenoid
By DJCW in forum Parts DeskReplies: 2Last Post: 12-06-2009, 02:46 PM -
Mist Removal in Pictures
By CrazyCarl in forum Ride, Record, CreateReplies: 1Last Post: 04-29-2008, 05:41 AM
комедии 2024 онлайн...
04-23-2024, 02:09 AM in Off Topic Discussions
