#1 Pulse adrenaline 250 valve adjustement technique!
- Jun 2015
- Whyteleafe
06-22-2015, 09:11 PMHi all,have a pulse adrenaline 250 and would apprecite any tips for correct valve adjustement as am experiencing misfire at high revs and been told poss air leak somewhere or dirt in the jets of the carb.it has onlydone a couple of thousand km ,so hopefully nothing too drastic is occuring .
- fuck off
06-24-2015, 03:54 AMI had similar
I changed the plug boot and spark plug - set the tappets
I ended up lifting the needle on groove so a little richer as well
#3 Re: Pulse adrenaline 250 valve adjustement technique!
- Jun 2015
- Whyteleafe
06-24-2015, 04:56 AMThanks for replying. I shall have a look around tonight. You wouldn't happen to know the correct clearance as I have now been told that the information contained in the Haynes manual maybe wtong!.My model is a pulse adrenaline250/lexmoto here in England. Timing mark location would also be useful. Brian
- fuck off
06-24-2015, 04:57 AMWhat motor? It's not that critical I think the Haynes manual will be ok
- fuck off
06-24-2015, 05:15 AMImageUploadedByTapatalk1435122788.318548.jpg
This is a CB200 engine
Good enough for CG also as these are shitty things to begin with
#6 Re: Pulse adrenaline 250 valve adjustement technique!
By Trig in forum MaintenanceReplies: 0Last Post: 06-22-2015, 09:08 PM -
pulse adrenaline 125
By fastfaz65 in forum Welcome to MCM!Replies: 0Last Post: 09-09-2014, 03:46 PM -
Pulse Adrenaline
By David-Hewitson in forum MaintenanceReplies: 1Last Post: 05-27-2012, 11:28 AM -
pulse adrenaline valve clearances?
By pulsepat in forum Dirt n' Dual-SportReplies: 9Last Post: 03-14-2012, 03:17 PM -
mikilon 250 valve adjustement
By perculator40 in forum MaintenanceReplies: 2Last Post: 07-30-2011, 02:59 PM
