#1 Why is my front brake rubbin ????? And how can I fix it??????
- Mar 2015
- northcarolina
08-12-2015, 02:01 AM0811152209.jpg0811152209a.jpg0811152210.jpg0811152213.jpg0811152213a.jpgSo I changed out my Qlink xp200's stock tires for some Shinko 705 90/90-21 went to put them on and everything went on fine. Except during the test ride I noticed a "knock" coming from the front wheel. It looked like the bolt heads connecting the rotor to the hub were rubbing the brake pads.
SO...I loosened the front wheel so it spun freely but it was still slightly rubbing then tightened the front wheel to the point it was very hard to spin then loosened it again to the point the front axle bolt's head was flush with the rest (point were the wheel spun freely)
Then.. I loosened two bolts connecting the brake to the bracket and spun the wheel many times. And by the time I tightened the "brake Adapter" bolts it seem to of helped some but there is some rubbing. Also my rotor is not warped al all.
I did another test ride and I could hear it rubbing but I didn't feel any vibrations. It just makes me worry. How Can I fix this ? I really want to ride tomorrow. I'll try to remember to put up some pics.Last edited by bullfrog; 08-12-2015 at 03:08 AM. Reason: added photos
#2 Re: Why is my front brake rubbin ????? And how can I fix it??????
- Mar 2015
- northcarolina
08-13-2015, 04:24 AMUpdate :
So with the wheel rubbing the brake slightly I decided to break those new tires here is some pics of the rotor after me riding it all day, It still rubs more than I like , how can I get it to not rub at all.
#3 Re: Why is my front brake rubbin ????? And how can I fix it??????08-13-2015, 11:05 AM
This type of caliper is a sliding pin . That is the caliper floats on two pins so you need to pull it apart and clean the pins and the inside of the holes. Then grease it with something like "coppercote".While you are at it remove the pistons and carefully clean those. Do not use sandpaper just a cloth with a little gas.
- fuck off
08-15-2015, 01:25 AMNo coppercoat!! Silicon based only and not petroleum
Ok you have the same issue as me - stretched caliper bolts to the fork
Remove the bolt and grind a little of the end to make it shorter by halve a mm or so
Do both job done
#5 Re: Why is my front brake rubbin ????? And how can I fix it??????
#6 Re: Why is my front brake rubbin ????? And how can I fix it??????
- fuck off
08-16-2015, 03:47 PMCopper coat is petroleum based and swells seals causing minor to major sticking slides
Totally the wrong products
Stretched bolts new a higher grade is best
Sort term fix grind a little
- fuck off
Head shake when using the front brake
By sprok in forum MaintenanceReplies: 8Last Post: 04-08-2015, 11:29 PM -
Spongy front brake
By sprok in forum MaintenanceReplies: 7Last Post: 09-29-2014, 03:58 PM -
Front brake Disc calipers for DF250RTC
By RacerX125 in forum Parts DeskReplies: 0Last Post: 06-14-2013, 06:42 PM -
Does anyone know how to fill the DF250RTC front brake lines?
By RacerX125 in forum StreetReplies: 9Last Post: 06-12-2013, 04:22 PM -
Lost front brake caliper bolt
By kingmarty45 in forum MaintenanceReplies: 7Last Post: 01-22-2009, 04:48 AM
