#1 Engine temperature with stainless steel exhaust08-07-2015, 11:34 PM
On the begining of my post I want to say hi to everybody, as this is my first time writing anything here. :)
I recently fitted my Superbyke RSP125 with a stainless steel downpipe and a stubby exhaust. Since then I think the engine gets a bigger temperature and it warms up quicker. Also while the engine is hot, the end can is cold and the downpipe only warm (you can touch It with a bare hand). I'm guessing It's probably something to do with the carburettor, but what?
Thanks in advance for any help ;)
#2 Re: Engine temperature with stainless steel exhaust08-07-2015, 11:58 PM
Hi and welcome to MCM ...
Not sure what you are asking ???? if your engine is getting to hot then its lean ??? if its to cold then the engine is running rich .... you need to pop out the spark plug and have a look .....
Good luck"Arguing on the Internet is like running in the Special Olympics, even if you win you're still retarded"
#3 Re: Engine temperature with stainless steel exhaust08-08-2015, 03:02 AM
That's exactly what I was asking ;) is it possible that changing the exhaust messed the whole carburetor setup?
#4 Re: Engine temperature with stainless steel exhaust
#5 Re: Engine temperature with stainless steel exhaust08-08-2015, 10:47 AM
How do I do that? As in which bolt on the carburetor to turn which way to adjust it? I've never done this before, but I've recently spent quite a lot of money on It and my budget is low, so I'm hoping I'll be able to do It myself.
#6 Re: Engine temperature with stainless steel exhaust08-15-2015, 11:04 PM
So I've tried adjusting the needle, I put it on the lowest setting but doesn't seem like It helped. If anything I'd say I made it worse. I've also fitted a K&N style filter now. Any ideas how to adjust that? It would be much appreciated.
#7 Re: Engine temperature with stainless steel exhaust
- Oct 2013
- skelmersdale
08-26-2015, 12:18 AMhttp://www.jba.bc.ca/JBCycle/Resources/jet-chart.jpg
Will help with what and where needs adjustingSinnis Vista, K157fmi. Koso electric speedos, rewired with English wire wiring loom including H.I.D headlight and a cigarette charger. 150cc big bore kit. 30mm mikuni carb with k&n filter. Bored out inlet manifold and 230cc cam. 110 main jet and 17/46 sprocket configuration.
DIY: Steel Mesh Brake Lines
By TrailOut in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 07-27-2013, 01:09 PM -
New exhaust
By allhale09 in forum Modifications (Cosmetic and Performance)Replies: 0Last Post: 11-04-2012, 03:37 PM -
My New Exhaust :)
By xltomm in forum Modifications (Cosmetic and Performance)Replies: 10Last Post: 02-19-2012, 09:53 PM -
Exhaust HELP
By xltomm in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 02-18-2012, 10:55 PM -
exhaust
By my_bloody_shineray in forum MaintenanceReplies: 0Last Post: 06-21-2009, 11:51 AM
