Thread: Paint removal
Results 1 to 5 of 5
#1 Paint removal
- Nov 2015
- march
11-12-2015, 11:27 AMHoping this is the correct.place to post this.I have bought a very badly abused bike (sfm roadster) need some advice on stripping 4 layers of paint and original. Decals of the petrol tank apart from using sanding disks can anyone suggest chemical steppers they have used with success. Cheer's
#2 Re: Paint removal11-12-2015, 05:15 PM
I did use one I liked, but it was local brand.
My two cents: use, not liquid, but gel.Ask me nothing - I DO NOT speak english. Really...
#3 Re: Paint removal11-12-2015, 09:36 PM
Heat gun is much safer than sanding disk (metal may sanded away) or chemical (may corrosive the metal) . Ur local paint supplier may give u the advice of the "correct" stripper.
#4 Re: Paint removal11-13-2015, 12:58 AM
If it's on metal then a heavy duty chemical paint-stripping gel will have that off with no problems. Chemical stripper works very quickly so it's best to keep an eye on it and clean up the mess as soon as the paint has come away from the metal.
On plastic it would be better to use a heat gun. Once the paint has softened it can be peeled off very easily.
#5 Re: Paint removal11-13-2015, 06:40 PM
On plastics, I would try with brake fluid (after some testing how those two react on each other).
Starter removal?
By Ragtop in forum ATV's/QuadsReplies: 5Last Post: 06-18-2015, 05:18 PM -
Motorcycle vinyl wraps alternative to paint
By bikerdoc in forum Modifications (Cosmetic and Performance)Replies: 0Last Post: 08-20-2013, 12:59 AM -
125 flywheel removal
By 50dude in forum MaintenanceReplies: 1Last Post: 05-06-2011, 01:10 PM -
rust and paint, recommendations?
By jape in forum MaintenanceReplies: 14Last Post: 04-17-2010, 05:35 AM -
Mist Removal in Pictures
By CrazyCarl in forum Ride, Record, CreateReplies: 1Last Post: 04-29-2008, 05:41 AM
комедии 2024 русские
Today, 07:03 AM in Off Topic Discussions
