Results 1 to 4 of 4
#1 Tachometer troubleshooting QM125-2D
- Nov 2015
- Great Britain
03-07-2016, 12:50 AMSince I was this succesful in changing the stator/pick up coil, I start to look into the digital tachometer's problem again.
Needle stays at 0 since I got the bike, sometimes jumps a little, but I think thats only when the bike is shaking...
Can you tell me THIS bike's source of the impulse for the tachometer? As I read it's different for certain bikes.
Also: how can I test this source to rule it out as a culprit?
Also: if it's ok, how can I test the very end of the wire goihng inside the tach clock? Check the voltage in it, or how?
#2 Re: Tachometer troubleshooting QM125-2D03-07-2016, 04:04 AM
Source = Pickup's + (don't trust ANY color code) coz u said that horrible story in http://www.mychinamoto.com/forums/showthread.php?8058
Check continuity (ohm) | current flow (amp | DON'T check this if knows nothing | a "short" can cause fire ) ...
Any pals know these nearby?Last edited by humanbeing; 03-07-2016 at 04:45 AM.
#3 Re: Tachometer troubleshooting QM125-2D
- Nov 2015
- Great Britain
03-07-2016, 06:08 AMThat's the CDI there on the picture?
I have a new pickup fitted since 3 days, and a new CDI is coming via mail-
So I presume if I fit the CDI and still no rev count, then either the wire loom, or the clock itself is faulty :(
Just missed a 27pound ebay auction for a complete sinnis stealth clockset...
No pals near me anywhere XD
I can check voltage, and current flow confidently, without damaging the multimeter ^^
but I need to learn to check continuity aswell- didn't looked it up until now.
By the way: my ignition-off parasitic drain started from 7.62 Milliamper with the old stator coil, now it's 0.38 mA with the new. - still bigger than 0.1 mA :( could the dead rev counter cause the rest of the leakage?
#4 Re: Tachometer troubleshooting QM125-2D03-07-2016, 07:40 AM
It's very healthy
From RV125(VanVan) shop manual http://postimg.org/image/jam4bvmql/
Sensor wire should shared w/ #6 in most case. https://translate.google.com/transla...htm&edit-text=
At ur own risk!!! 3k rpm /6k rpm signal generator https://translate.google.com/transla...790&edit-text=Last edited by humanbeing; 03-07-2016 at 08:00 AM.
No spark at all, and very suddenly- QM125-2D
By Packleader in forum MaintenanceReplies: 2Last Post: 03-07-2016, 01:49 AM -
Superbyke RSR/sinnis stealth/qm125-2d parts online to ship to the UK
By Packleader in forum MaintenanceReplies: 2Last Post: 11-24-2015, 11:47 AM -
Pulse Adrenaline 125 Tachometer
By daniel_14 in forum MaintenanceReplies: 2Last Post: 08-06-2013, 09:46 AM -
Qingqi QM125/200 upgrades
By Ed209 in forum Modifications (Cosmetic and Performance)Replies: 11Last Post: 02-15-2013, 11:30 PM -
Tachometer indicates more revs than real! Qingqi supermotard
By andres357mag in forum MaintenanceReplies: 3Last Post: 06-23-2011, 05:30 PM
комедии 2024 онлайн...
Yesterday, 02:09 AM in Off Topic Discussions
