Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11 Re: How does Ssr lazer 5 moped vaccum lines connect
    Senior C-Moto Guru Zorge's Avatar
    Oct 2009
    Σερβία
    I could not find now some pictures, but there is some contraption that involves thin pipe that comes out of the head, some manifold outlet, few hoses...
  2. #12 Re: How does Ssr lazer 5 moped vaccum lines connect
    C-Moto Not-so-Noob
    Mar 2016
    San diego
    Will post pics tomorrow thanks for all the help. Their are no dealers of the lazer 5 in san diego only in LA.
  3. #13 Re: How does Ssr lazer 5 moped vaccum lines connect
    C-Moto Not-so-Noob
    Mar 2016
    San diego
    Was not able to upload pictures tried with my phone and laptop. some issue with the forum
  4. #14 Re: How does Ssr lazer 5 moped vaccum lines connect
    Senior C-Moto Guru MJH's Avatar
    May 2010
    US
    yeah images have to be on the web to upload, your pc does not have a URL, like image shack or photobucket etc. The location of the image file has to be http://....not C:...
    The site software sees http://location on web it does not see C: location on your puter.
  5. #15 Re: How does Ssr lazer 5 moped vaccum lines connect
    C-Moto Not-so-Noob
    Mar 2016
    San diego
    will a c70 cylinder and piston fit on my xr50 bottom and lazer 5 head set up and will it make a significant upgrade?
    finnaly got images up, thanks
    https://www.dropbox.com/sh/rz2hpombm...zvndlBqQa?dl=0
  6. #16 Re: How does Ssr lazer 5 moped vaccum lines connect
    Oct 2009
    Σερβία
    OK.
    I'm taking a guess: this alloy thing on the pic No.2, with three hoses is some vacuum valve. Thin hose goes to the ioutlet on the intake manifold, one of the thicker hoses goes on the pipe we see on the pic No.1, and the other goes to the single remaining outlet we see on the pic No.3.
    And again, I don't see how this contraption do some real job in decreasing pollution emissions, and the most definitely, engine will run good even without it.
  7. #17 Re: How does Ssr lazer 5 moped vaccum lines connect
    Oct 2009
    Σερβία
    Quote Originally Posted by Electrorange View Post
    C70 cylinder (or any other Chinese 47 mm diameter cylinder for horizontals) - yes.
    C70 stock 47mm piston together with stock Lazer's 50cc head - no. I told you why - http://www.mychinamoto.com/forums/sh...ll=1#post80583
    So, if you ask me, cheapest solution will be to fit, for example, this piston set - http://www.ebay.com/itm/GY6-50-80cc-...yF__XQ&vxp=mtr ("in breve" - flat head, 13 mm pin, skirt shorter than on a standard 47mm piston for horizontals), and standard 47mm cylinder for horizontals, such is this one - http://www.ebay.com/itm/Cylinder-Bar...sAAOSwEetWAl1X.
    There is also "Plan B" for a cylinder: take your stock 39 mm diameter cylinder together with the 47 mm piston you bought and go to machine shop. They can bore out old cylinder and do some decent honing, so new piston can fit perfectly.
  8. #18 Re: How does Ssr lazer 5 moped vaccum lines connect
    C-Moto Not-so-Noob
    Mar 2016
    San diego
    i will try using your guide and if it does not work i will cap it by making a plate. thank you
  9. #19 Re: How does Ssr lazer 5 moped vaccum lines connect
    C-Moto Not-so-Noob
    Mar 2016
    San diego
    If I cap both the tubes, the one from the head and the one one the intake. will I have any issues?
  1. SSR Lazer 5 moped?
    By birdmove in forum Street
    Last Post: 03-11-2015, 09:30 AM
  2. DIY: Steel Mesh Brake Lines
    By TrailOut in forum Modifications (Cosmetic and Performance)
    Last Post: 07-27-2013, 01:09 PM
  3. Pulse Adrenaline in 2 lines
    By japanzzz in forum Street
    Last Post: 11-11-2012, 09:12 AM
  4. Pulse Adrenaline in 2 lines
    Last Post: 11-10-2012, 11:51 PM
  5. Sym Jet Moped Carb Settings help ?
    By Chronicz in forum Maintenance
    Last Post: 05-16-2012, 06:49 PM
