Thread: Help! SO Many Wires!
#1 Help! SO Many Wires! Pulse Adrenaline Loom.
- Mar 2016
- UK
03-29-2016, 10:58 AMHello,
I have a Pulse adrenaline engine I bought from somebody breaking a bike. I also have the wiring loom. I am going to install it into an off road buggy. I have worked out where most of the connections go between the CDI and the engine, coil etc, but there's a few things I can't work out. There are 2 connectors that have about 9 pins each in them what are they for on the bike? There is also something that's a bit beaten up but it looks like a back disc with a number of dots on it at the end of a cable. I have no idea what its purpose is. Also the loom has been cut from the bike so I don't have the ignition barrel etc, so I can't work out which wires were connected to that. If anybody can help with any of this I'd be very grateful.
Cheers
H
cm1.jpgcm2.jpgcm3.jpgLast edited by Buggy; 03-29-2016 at 07:39 PM.
#2 Re: Help! SO Many Wires! Pulse Adrenaline Loom.
#3 Re: Help! SO Many Wires! Pulse Adrenaline Loom.
- Mar 2016
- UK
#4 Re: Help! SO Many Wires! Pulse Adrenaline Loom.
- Apr 2016
- Burton Latimer
04-03-2016, 02:16 PMThe black disc is the Gear position sensor that would have been behind the left engine cover of the bike.
Without this you will have no neutral light or gear indicator on the dash.
The first pic looks like the wiring connectors for the handlebar switches-starter, lights etc.
And one may be the dash/clocks connector.
#5 Re: Help! SO Many Wires! Pulse Adrenaline Loom.
- Mar 2016
- UK
110cc extra wires. gear indicator???
By arlie1180 in forum Parts DeskReplies: 6Last Post: 08-03-2015, 06:41 AM -
Brown and red wires?!?!?
By ThatGuyLiam in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 02-07-2014, 04:06 AM -
Need help changing rectifier, simple if you know what the wires are
By ross_1992 in forum MaintenanceReplies: 3Last Post: 01-12-2014, 02:48 AM -
Smoking wires when starting Kinlon 200SM
By halfcasted in forum MaintenanceReplies: 3Last Post: 01-28-2012, 09:02 PM
Get vivid impressions and...
