#1 LEXMOTO XTRS 2014 HELP ALARM INSTALl
- Jun 2016
- london
06-21-2016, 07:30 PMHi guys i got LEXMOTO XTRS 2014 need to install lexteh alarm with immobilizer but i can't find the plug and play sokcet for it i found one under the guagues but thats just for the guages when i plug it in there it don't work could you tell me where i can locate the control box or the right socket to fit the alarm
also don't know if this is the section to post
best regards
Adrian from london :)
#2 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl06-22-2016, 02:00 AM
Generic chinese stuff use square 8 pin (size ~2cm)
If can't p&p, tap it to the right wire(s)
+ (Alarm's energy source. U can hide it as secret as possible, theft can't find & cut at once... )/ - / Blinker(s) | [IGN off ] | + that controlled by lock s/w (example BLACK near lock / brake s/w etc) | starter solenoid (+)
#3 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl
- Jun 2016
- london
06-22-2016, 07:59 PMso i found this one near the headloght but when i plug it in it don't work and that is bassicaly for the speedo and is there one more of this on the bike? best regards,
Adrian
#4 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl06-22-2016, 10:45 PM
P&p connector can be found under the seat or inside the headlight...
#5 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl
- Jun 2016
- london
06-23-2016, 05:42 PMso there should be one spare one just to connect the alarm???? or can i get a splitter 8 pin??
#6 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl
- Jun 2016
- london
06-23-2016, 05:49 PMbecause i found the connector but there is only one if i disconnect it then i cant have the speedo working etc
#7 Re: LEXMOTO XTRS 2014 HELP ALARM INSTALl06-23-2016, 09:30 PM
Some model had p&p connector, some don't . Ask local dealer/ official importer for details...
http://www.ebay.co.uk/itm/181695613981
If your vehicle hasn't got the appropriate 9-pin connector then the alarm will need to be wired directly into your vehicle's existing loom
lexmoto xtrs
By drago in forum StreetReplies: 1Last Post: 02-10-2015, 01:57 PM -
Lexmoto xtrs 125
By lomi in forum MaintenanceReplies: 5Last Post: 09-24-2014, 04:40 PM -
Lexmoto xtrs helpppp
By Abeales33 in forum Dirt n' Dual-SportReplies: 0Last Post: 11-14-2013, 11:11 PM -
lexmoto xtrs
By weedod in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 05-19-2013, 11:23 AM -
end can for lexmoto xtrs 125
By xtrs125 in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 02-19-2013, 10:46 AM
комедии 2024 онлайн...
