Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 250cc twin won't start
    C-Moto Noob
    Apr 2017
    new zealand
    Hey everyone I have a 250 cc inline twin quad 253fmm-c, it wont start.
    I have
    cleaned the carb 3 times
    fresh fuel
    new plugs
    checked valve timing and valve clearance, both right
    compression test 160 in both cylinders
    checked for spark , good spark in both
    Does anyone have any ideas, thanks
    motor maniac ShuBen's Avatar
    Jul 2010
    Beijing
    Airfilter?
    SWM RS500R, R1200GS LC
  3. #3 Re: 250cc twin won't start
    Life Is Good! ChinaV's Avatar
    May 2008
    Guangdong, China
    A little blast of starter fluid might be helpful to see if you're actually getting a strong enough spark. WD40 works in a pinch.
  4. #4 Re: 250cc twin won't start
    C-Moto Noob
    Apr 2017
    new zealand
    Air filter is clean and I have tried it on and off thanks
  5. #5 Re: 250cc twin won't start
    C-Moto Noob
    Apr 2017
    new zealand
    I haven't tried starter fluid yet but I will give it go, the engine tries to go but won't Rev at all
  6. #6 Re: 250cc twin won't start
    C-Moto Noob
    Apr 2017
    new zealand
    I put the carb through an ultrasonic bath but still no go, im out of ideas other than replacing all the electrics
  7. #7 Re: 250cc twin won't start
    C-Moto Guru
    Sep 2011
    Sofia, Bulgaria
    Did you try playing with the air-fuel mixture screw on the carb? Is the plug wet after you crank it for a while?
  8. #8 Re: 250cc twin won't start
    C-Moto Noob
    Apr 2017
    new zealand
    Yes I have mucked around with it, what would you recommend a good starting point 1, 1/4 turns from fully wound in?
    Jul 2010
    Beijing
    Any former activity on inlet valves, e.g. adjustment? Maybe nearly no opening?
    Was camshaft out? Maybe timing is wrong. Happens easily by just missing one tooth or use the wrong marker on the fly wheel.
    I assume its somehow a timing problem.
    Jul 2010
    Beijing
    Oh, and check the connection between carb and cylinder. When u have air leakage there then u can play on the carb for ages
  1. twin port cg clone head
    By badger8v in forum Modifications (Cosmetic and Performance)
    Last Post: 01-23-2015, 06:25 AM
  2. Benelli 300 twin
    By td_ref in forum Industry News and Moto Talk
    Last Post: 02-10-2014, 09:54 AM
  3. cold start / kick start problem
    By tylerkaz in forum Maintenance
    Last Post: 06-03-2012, 11:05 PM
  4. Selling my V-Twin 250 - Beijing
    By Dani77 in forum Bike Market - Classifieds
    Last Post: 06-26-2011, 08:07 AM
  5. V-Twin Technicians in China
    By Pal in forum Asia
    Last Post: 06-05-2011, 03:35 PM
