Thread: 200cc qingqi at help
#1 200cc qingqi at help
- Sep 2017
- Hampton, virginia
09-13-2017, 08:50 PMI have a 200cc CB style qingqi ATV that I got for free from a guy I bought a Jeep from. I figured I'd try to fix it and use it, but I'm having a hard time finding parts that fit. I have found a few but not enough. Ex. Gasket kit that actually fits. I was wondering if I could get some help making sure I properly identified my engine and if anyone has any places that they know sell parts for this engine. I'm trying to do a complete engine rebuild because it sat for 3 years and the cylinder was rusted to the piston head, I'm ordering a top end kit, I got new valves because the old ones were rusted shut, and I found a new carb, but I can't find anything else. Not a CDI, rectifier, ignition switch(previous owner broke the key in the switch), starter, plastics, gasket set, pick-up coil.
#2 Re: 200cc qingqi at help
- fuck off
09-18-2017, 01:29 AMHi
this is a Zongshen 200 ZS if I am nt wrong is a Zongshen 200 motor so very generic.
CB125-250 is all much of a muchness and simular etc.
Gaskets should be easy in China and so would be the other parts etc I could look to source and send what you need etc.
Or search EBay for CB200 CB250 stuff
#3 Re: 200cc qingqi at help
- Nov 2017
- europe, Finland, arctic circle
11-28-2017, 08:20 PMThat engine and about all electronics are same as on my Bashan BS200S-3 atv. mine also have ZongShen engine at it, same type ZS169FML.
all ignition parts at it are same as on many PitBike's. reg-rec is also common type among Gy5 150cc 200cc 250cc categoryes.
on this type of ATV you can use also bashan Bs200-S7 digital tacho's.
plenty of parts available, when you know where to look for.
Bashan from all the ATV's using 169FML, is defenitely the Best most known good BRAND. for Bashan its most easy to find parts and offical Dealers. also easy to find free PDF's like parts list pdf's, W.S.M's etc Wiring-Diagrams.
2nd most common clone to BS200S-3 is Shineray ATV StixeII 200cc.
others are Mainly Re-Branded and more difficult to deal with....
When searching engine parts, it also helps to use "CG200" name-code, for the more Generic usable engine parts, like engine gasket kits......
#4 Re: 200cc qingqi at help11-29-2017, 04:57 AM
Weirdo 69mm CB200 had minor difference btw the chonda
Piston is 17mm pin
Measures 1st b4 order anything. Some stamped 69 is a 63.5!!!
Selling 2014 Qingqi 200cc in Beijing, Jing B plates - 7000 RMB, <1000KM
By shanghaipete in forum Bike Market - ClassifiedsReplies: 2Last Post: 07-22-2016, 04:53 AM -
Can i put a 200cc motor in my 200cc Qingqi?
By jazza_williams in forum Dirt n' Dual-SportReplies: 13Last Post: 06-19-2013, 10:06 PM -
qlink 200cc on a national atv
By Hotrod blaster in forum Dirt n' Dual-SportReplies: 7Last Post: 05-01-2013, 04:10 PM -
exhaust thing for my Kinlon 200cc
By jape in forum Modifications (Cosmetic and Performance)Replies: 11Last Post: 01-09-2011, 03:25 AM
