Results 1 to 1 of 1
#1 Which ignition coil is best among below two?
- Jul 2016
- Asia /Pakistan
12-25-2017, 05:05 PMHi
I have lifan 1p54fmi 124cc 54mm square bore engine with big valves.
How do I know which ignition could is best for it?
One coil is from 85cc bikes produced locally it's primary winding resistance is 0.6 ohm and secondary winding resistance is 4.7K ohm.
Second is from cg 125 its primary resistance is 0.4ohm and secondary is 3.4k ohm
If I look for another one then what parameters should I look for in it?
Regards
2006 qlink x-ranger 200cc ignition coil
By captainbone in forum MaintenanceReplies: 2Last Post: 05-10-2014, 07:32 PM -
superbyke ignition fault
By david.rmr125 in forum MaintenanceReplies: 0Last Post: 09-03-2013, 09:54 PM -
Upgrading the ignition system
By spencer2004 in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 10-08-2012, 01:03 PM -
ignition wiring
By markm111273 in forum Parts DeskReplies: 5Last Post: 06-24-2011, 05:14 AM -
pulse adrenaline ignition
By heeby in forum MaintenanceReplies: 1Last Post: 03-03-2011, 11:48 PM
