#1 Convert water cooled engine to air cooled ( 163MM TO 163FML)
- Jul 2016
- Asia /Pakistan
12-10-2017, 07:08 AMAoa,
I have 163ML engine. It's water cooled at the moment. I want to convert it to air cooled. I m of the view that replacing only head and cylinder and removing water impeller and shaft will do the job. Any bush can made to shut the holes of the impeller shaft to avoid engine oil coming to the compartment used for water pump.
Since it's 163ML stock is Chinese nomenclature for water cooled single cylinder 63mm bore engine. And it's equivalent air cooled sibling is 163FML.
So head cylinder swap from it will do the job.
Description of the water cooled engine in question is given at below link.
http://cqlihan.en.alibaba.com/produc...le_engine.html
Is it doable?
Anyone done it?
Regards.
- Jul 2016
- Asia /Pakistan
08-22-2018, 08:32 AMAnyone swaped had cylinder block from 163ml air cooled to water cooled one?
#3 Re: Convert water cooled engine to air cooled ( 163MM TO 163FML)
- Jul 2016
- Asia /Pakistan
05-14-2020, 10:55 PMBump @humanbeing
#4 Re: Convert water cooled engine to air cooled ( 163MM TO 163FML)
- Jul 2016
- Asia /Pakistan
05-14-2020, 10:57 PM[QUOTE=humanbeing;89996]
please if you can guide
#5 Re: Convert water cooled engine to air cooled ( 163MM TO 163FML)
- Jul 2016
- Asia /Pakistan
06-15-2020, 02:54 PMBump.
I need to know if it's possible to convert the water cooled to air cooled version?
Need service manual for Chinese water cooled 200cc engine
By chamjiee in forum ATV's/QuadsReplies: 1Last Post: 01-25-2017, 04:32 AM -
h.p. of sohc water cooled 250?
By gusmanxtr in forum Dirt n' Dual-SportReplies: 0Last Post: 07-17-2014, 03:15 PM -
250 water cooled wanted
By tradedog in forum Welcome to MCM!Replies: 8Last Post: 02-14-2012, 07:29 PM -
Zongshen 150 water cooled
By JamesW in forum Dirt n' Dual-SportReplies: 3Last Post: 05-18-2009, 11:02 AM -
2007 shinray atv 197 cc engine 4 speed water cooled with reverse
By loveday0818 in forum Parts DeskReplies: 1Last Post: 05-13-2009, 07:35 PM
