Results 1 to 3 of 3
  1. #1 1p54fmi stator resistance is it normal?
    C-Moto Not-so-Noob
    Jul 2016
    Asia /Pakistan
    Hi I have 1p54fmi. No spark problem.
    Checked the resistance of primary side of ignition coil its 0.6ohm. Secondary coil resistance is 4.7k ohm.
    Stator high tension coil resistance is 425ohm. And when I connect the red/black wire from stator to the case and kick I get a spark which is not as strong as one would get from the secondary side of the ignition coil. But I suspect that a spark from the ac charging wire to cdi means high tension coil is ok? Resistance of the pulsar coil is 135ohm.
    I have a spare cdi from cg125 and that has two connectors (one 4pin second 2 pin). Whereas my stock cdi is 6 single pin ( actually 5 pin as the place for 6th pin is empty).
    So I cut wires and found an adapter for the 2pin cdi and wired it according to color code. And tried that cdi too but no spark.
    What does above mean? What is good what is faulty?
    Regards
    Sent from my Nexus 5 using Tapatalk
  2. #2 Re: 1p54fmi stator resistance is it normal?
    Dec 2008
    Google how to build a "Peak Volt Adapter" (modern Honda shop manual don't tells ohm reading from stator's coil anymore)
    Reading should be something similar to
    C-Moto Not-so-Noob
    Jul 2016
    Asia /Pakistan
    Quote Originally Posted by humanbeing View Post
    Not a shop can't build that system or buy it.
    I will order replacement item. But don't know which one should I suspect?
  1. loose pipe is this normal?
    By howie17 in forum ATV's/Quads
    Last Post: 04-12-2017, 09:57 PM
  2. 18 pole stator
    By arancara in forum Modifications (Cosmetic and Performance)
    Last Post: 08-14-2013, 10:57 AM
  3. Stator coil (Magneto)?
    By Krasi in forum Maintenance
    Last Post: 05-23-2013, 08:22 PM
  4. TumToe is here; please continue on as normal...
    By TumToe in forum Welcome to MCM!
    Last Post: 09-24-2011, 06:11 PM
  5. Stator Coils Specs/Info
    By stacyc72110 in forum Maintenance
    Last Post: 06-14-2010, 12:56 PM
