Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
  1. #1 CFMoto 650NK/TR parts numbers and maintenance guide
    Senior C-Moto Guru ZMC888's Avatar
    Oct 2008
    Zibo, Shandong - Sometimes SW England
    Hi all, I'm looking for the parts numbers/types for the NK/TR.
    1. Brake pads
    2. Oil filter
    3. Battery
    4. Spark plugs
    5. Tire size in both metric and imperial systems
    6. Oil rating
    7. Coolant type
    8. Air filter type
    .....and any other torque settings, oil change intervals, links etc. I think CFMoto information is best, but Kawasaki ER6 information is good when CFMoto unavailable/incomplete.
  2. #2 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2008
    ER6N bolt checking guide, anyone got any torque values?
  3. #3 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
    Zhejiang PRC, OZ, NZ
    Quote Originally Posted by ZMC888 View Post
    1. Brake pads
    LHS Front: A000-0801A0
    RHS Front: A000-0801B0
    Rear: A000-080280
    2. Oil filter
    Oil filter: 0700-0700200
    3. Battery
    Battery: 12V10Ah
    4. Spark plugs
    Spark plug: CR81I
    Plug Gap: 0.7~0.9mm
    Tightening Torque: 15N.m
    Front: 120/ 70 R17 (58H) Up to 236kg; 280kPa, minimum tread depth 0.8~1mm.
    Rear: 160/ 60 R17 (69H) Up to 325kg; 280kPa [(?!) weird front and rear same tyre pressures!?] minimum tread depth 0.8~1mm.
    6. Oil rating
    SAE 15W-40/SG
    Viscosity: ELF 10W-40
    Type: JASOMA2 SJ
    7. Coolant type
    Coolant: Check the coolant level daily. Change the coolant every 2 years. Coolant containing corrosion and rust inhibitor chemicals should be used only.
    .....and any other torque settings, oil change intervals etc.
    Fuel: RON-93 Use only unleaded gasoline. Never use leaded gasoline. Leaded gasoline signifcantly reduces the capability of the catalytic converter.
    Drive chain: Slack 30~40mm
    Throttle grip play: 2~3mm
    Clutch lever play: 2~3mm
    Engine oil Drain Plug: 30N.m
    Oil flter: 17.2N.m
    Idle Speed: 1300130 rpm
    Rear axle nut: Tightening Torque: 108N.m
    Brake Pedal Travel: 10mm
    Rear suspension adjustment: The standard setting position for an average-build rider of 75 kg (165lb) with no passenger and no accessories is setting No.3.
    The maximum recommended load on addition to vehicle weight is 180kg (397lb), including rider passenger, baggage and accessories.
  4. #4 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
  5. #5 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
  6. #6 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
  7. #7 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
  8. #8 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2009
  9. #9 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2008
    Thanks Bikerdoc, great information
    Engine Oil Capacity
    2.0 L [When filter is not removed]
    2.2 L [When filter is removed]
    2.6 L [When engine is completely dry]
    Quote Originally Posted by bikerdoc
    Battery: 12V10Ah
    But what size battery? I got a wet battery with the bike, I'm not sure about anyone else but I'd like to switch to a dry Yuasa, what dimensions/code number do I need?
  10. #10 Re: CFMoto 650NK/TR parts numbers and maintenance guide
    Oct 2008
    Brakes LHS Front: A000-0801A0
    Rear: A000-080280
    These codes bring me to a dead end. Do you have any different codes or any links to where I can buy replacements?
    Same happens with oil filter type. Seems not be an actual code number just an internal CFMoto code of some kind. Also need air filter codes.
  1. New CFMoto 650NK blog x2
    By ZMC888 in forum Street
    Last Post: 03-29-2014, 06:38 AM
  2. new levers for cfmoto 650nk
    By pommie in forum Modifications (Cosmetic and Performance)
    Last Post: 01-10-2014, 05:08 PM
  3. My Review of the CFMOTO 650NK
    By Topmanda in forum Street
    Last Post: 09-24-2013, 12:59 PM
  4. CFMoto 650NK sport bike
    By Lao Jia Hou in forum Street
    Last Post: 08-28-2012, 04:23 AM
  5. Qlink, QingQi 200 Parts Numbers and Diagrams
    By CrazyCarl in forum Dirt n' Dual-Sport
    Last Post: 09-22-2009, 04:00 PM
