#1 Bike only starts if Carburetor insulator nozzle is open
- Jul 2016
- Asia /Pakistan
03-16-2018, 10:15 AMHi
I had a Chinese 125cc ohv engine. It had some euro 2 standard device setup. There was an air pipe going from the carburetor intake manifold insulator to that euro 2 device.
I swapped the engine with a water cooled 200cc Ohv bit that engine doesn't have that euro setup.
Now if I use that pz27 carb with this 200cc engine it would only start of that nozzle on insulator is left open. If I close it engine will shut off. If it's closed and I try to start engine it won't start.
But if it's left open it's sucking air and mixing it with the air/fuel mixture already meter by carb won't that lean it? It might injest water or dirt.
It's that little black nozzle on the carb.
#2 Re: Bike only starts if Carburetor insulator nozzle is open03-16-2018, 10:30 AM
i guess that carb is simply too small for 200CC. Maybe try a PZ32 or even 34.
SWM RS500R, R1200GS LC
- Jul 2016
- Asia /Pakistan
03-16-2018, 10:43 AMYes it not perfect size. But why is it starting only and only if that nozzle is opened?
My understand is that that nozzle will further lean the air fuel mixture leaving the carb. And hence blocking that nozzle the bike should run even better m its acting as a sort of leak. But I m unable to find why is it not starting with that hole blocked.
I have up up jetted the carb. Bigger Mj, pj, raised the needle in c clip.
#4 Re: Bike only starts if Carburetor insulator nozzle is open03-17-2018, 02:13 AM
you use a carb with too small cross section, additionally you give more fuel.
The logic for me is the bike gets too less air. Check your spark plug if its black and or wet.
Alternatively you can try to remove the air filter and test run it.
Or you can try run the bike with removed connection between airfilter and carb to suck more air in.
I have a small 125cc and when I open the choke fully it will die within short time after start.
Then I have to close the choke about half and it will run again.
The conclusion is that the relation Fuel to air is not correct. -> too much fuel
You have too less oxygen available to burn the fuel.SWM RS500R, R1200GS LC
- Jul 2016
- Asia /Pakistan
03-17-2018, 06:23 AMThis can't be die to too much fuel. As the carb is from a 125cc engine. No serious jetting is done on it. Except that a big bore was installed on 125to male that 150cc and this carb was running perfectly on that.
Tried with air filter removed still isn't starting. Not even for a fraction of a second.
This engine with this carb and jet settings are used by other guys and is a common swap.
- Jul 2016
- Asia /Pakistan
03-17-2018, 04:35 PMThanks I resolved it. Seems like the idle adjustment screw was out too much.. Don't know how that happened as just removed the carb and manifold from head and immediately installed on the 200cc non euro head..
Seems like that screw would create some vacuum and let the slide move up..
I shut that hole by inserting a screw
Bike still starts when turned off by key.
By giant1985 in forum StreetReplies: 4Last Post: 11-06-2015, 09:41 AM -
Help with carburetor on Zongshen 125 - 18
By Donnelly in forum StreetReplies: 8Last Post: 05-15-2015, 08:18 PM -
Teach you move the needle in the carburetor 4t
By motor in forum MaintenanceReplies: 0Last Post: 09-03-2013, 07:57 AM -
carburetor question?
By hawaiian-style in forum MaintenanceReplies: 3Last Post: 08-27-2011, 04:28 AM -
Kick starts ?
By Sprocket in forum Modifications (Cosmetic and Performance)Replies: 5Last Post: 04-02-2010, 02:01 PM
A Working VPN Solution?
