#1 SINNIS APACHE 250 (QM250GY) Fuel Pump stuck open/on
- May 2017
- Wales
04-26-2018, 06:48 PMHi guys,
My Sinnis Apache 250 (QM250GY-F fuel injection model) has developed a fault - the fuel pump seems to be stuck open.
When I turn off the ignition and the engine with the ignition key and the handlebar kill switch the Fuel injection pump keeps going until I disconnect the battery.
Th bike has been standing for a few months and the petrol may have crystallized resulting in it being now stuck on. I've done over 60 miles to try to flush it through but it's still a problem.
Any HELP would be appreciated.
Mark
#2 Re: SINNIS APACHE 250 (QM250GY) Fuel Pump stuck open/on04-27-2018, 05:40 AM
I guess its an electrical problem.
The fuel pump must switch of with kill switch and/or ignition turned off.
If its still running there must be short cut somewhere that supplies power to the pump.
But basically I can hardly imagine this as the ignition lock does a physical power cut off.
Have you installed additional stuff where you redirect power to it?
Is for what ever reason the ignition lock short cutted?
You need a voltmeter to find that bridge.SWM RS500R, R1200GS LC
#3 Re: SINNIS APACHE 250 (QM250GY) Fuel Pump stuck open/on
Sinnis Apache 250 -QingQi QM250GY-F through Wales
By mark.evans101 in forum Ride Reports and MeetingsReplies: 8Last Post: 06-11-2017, 01:28 PM -
Think I'm getting a Sinnis Apache..
By Stevie1337 in forum Welcome to MCM!Replies: 4Last Post: 08-17-2014, 10:42 PM -
Sinnis apache mod
By Bradleyrayner in forum Modifications (Cosmetic and Performance)Replies: 4Last Post: 07-02-2014, 09:50 PM -
Sinnis Apache
By JamieAldridge1 in forum Modifications (Cosmetic and Performance)Replies: 4Last Post: 09-27-2012, 07:17 AM -
2010 Qlink XF200 loss of power (fuel tank vacuum) at high rpm, wide open throttle
By lakeclark in forum MaintenanceReplies: 6Last Post: 08-13-2011, 07:03 PM
комедии 2024 онлайн...
Yesterday, 02:09 AM in Off Topic Discussions
