Thread: 5 springs or 6 springs clutch?
Results 1 to 1 of 1
#1 5 springs or 6 springs clutch?
- May 2017
- UK
06-19-2018, 09:15 AMI am modifying a standard clutch as found on 244 and 253 engines. Normally they have 4 springs. I am wanting to upgrade the clutch because I sometimes pull a trailer, and it looks like the inner bits for a CG200 clutch will fit right in.
There are a few variations of the "CG series" clutch using 4, 5, and 6 springs and standard and wide plates. I have decided to go with the inner clutch hub that uses wide plates.
I am wondering how hard the clutch lever pull is on the 6 spring clutch. I don't want to make the upgraded clutch a tiresome effort to pull so I am asking if anybody has experience with the 5 and 6 spring CG style clutches used often on tricycles and things that use the CG 150/200/250/300 style engines.
Looking for clutch info
By mzts250 in forum Modifications (Cosmetic and Performance)Replies: 4Last Post: 11-01-2017, 02:04 PM -
RMR 125 Clutch Issues?
By DWJINSANE in forum MaintenanceReplies: 3Last Post: 08-08-2017, 02:23 PM -
were to buy clutch
By floater in forum ATV's/QuadsReplies: 1Last Post: 10-05-2014, 12:19 PM -
clutch problem
By chanley02 in forum MaintenanceReplies: 19Last Post: 06-01-2010, 12:15 AM -
Clutch Noise
By Supersignet in forum MaintenanceReplies: 11Last Post: 05-30-2008, 09:30 AM
