#1 Throttle cable issue - Pulse Adrenaline.02-14-2013, 06:48 PM
Can the wrong fitment of a throttle cable stop an engine from starting ?
I ask as the last I remember just before I gave up with the bike two years ago was it not starting after fitting a new throttle cable, it still won't start and I have done everything else- clean fuel, cleaned carb twice, I have a good healthy spark and the air filter is not blocked, but it won't start.
Removing the spark plug and cranking over it is clear no fuel is getting to the combustion chamber, but there is nothing wrong with the carb, so I can only think back to two years ago and I gave up because it wouldn't start after fitting a new throttle cable, so is the problem the cable somehow ?
Is there a special procedure to fitting the throttle cable to these things ?
The routing is correct and it's not trapped anywhere.'07 Pioneer Pulse Adrenaline 125, ( XF 125 GY ) Suzuki clone ; K157 FMI engine
#2 Re: Throttle cable issue - Pulse Adrenaline.
02-15-2013, 02:12 PMIf the throttle cable is too short or out of adjustment it could hold the throttle open enough to prevent the engine from starting.
1)With the throttle cable attached remove your carb and look through the outlet (the side that connects to the engine) and look at the small gap between the throttle slide and the carb body; there should be a small gap of a couple of mm.
2) If it is too big or small then give the throttle a bit of slack using the adjusters which should be located on the throttle cable near the carb and the handlebars
3) Adjust the idle speed screw located on the side of your carb to get the gap between the throttle slide and the carb body to roughly the right size
4) Fit the carb back to the cylinder head and attempt to start the engine, if it starts that give it some time to warm up then fine-tune the idle speed, if it does not start play around with the idle speed adjuster and try again
5) Adjust the slack in the throttle cable so that you have 2 - 6mm of freeplay on the throttle
If that does not work then you could try a new carb; the stock carb is a Mikuni VM22. You can get one from here http://www.ebay.co.uk/itm/MIKUNI-VM2...item35c187cedf
If none of that works the only other possibilities are lack of compression or an issue with the valve train. A compression issue could be caused by damaged piston rings, valves or a very bad head gasket leak. You could take it to a mechanic who will be able to do a compression test for you or you can by compression tester kits from Amazon for about £25.Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#3 Re: Throttle cable issue - Pulse Adrenaline.02-16-2013, 12:50 AM
#4 Re: Throttle cable issue - Pulse Adrenaline.02-27-2013, 06:19 PM
Excellent advice !!!
Thank You !!!
This was just what I was looking for and now the bike runs. The throttle slide was in wrong to start with, that corrected I did as you have suggested and the thing actually started on the choke mechanism which it never did before, mine the pilot screw setting is different where I understand before looking at the plug, it was running a bit fuel rich.
But it's been standing outside for two years, complete with solar charger fitted, so the battery was good, but it runs and it drives and everything works with only two electrical snags to sort out and bit of tidying up due to surface rust, but down here, I am haf a mile from the sea and what weather we get comes off that mostly,
The electrical snags are all common to the right hand handlebar electrics control, so I think there is my culprit and besides the throttle cable needs lubing, it was a bit sticky, so do that job when investigating the electrical snags.
But thanks again, this is just the sort of information that I thrive on.'07 Pioneer Pulse Adrenaline 125, ( XF 125 GY ) Suzuki clone ; K157 FMI engine
#5 Re: Throttle cable issue - Pulse Adrenaline.
02-27-2013, 09:59 PMYou're welcome, I'm glad to hear that you got it sorted.
#6 Re: Throttle cable issue - Pulse Adrenaline.
- Dec 2013
- Northampton
#7 Re: Throttle cable issue - Pulse Adrenaline.
- Sep 2018
- Plymouth
QLink throttle cable loose on carb
By get_out_and_push in forum MaintenanceReplies: 3Last Post: 06-18-2012, 02:37 AM -
pulse adrenaline throttle cable
By Rodders in forum MaintenanceReplies: 23Last Post: 04-20-2011, 02:12 PM -
clutch cable pulse 125
By sammy in forum MaintenanceReplies: 3Last Post: 10-25-2010, 09:50 PM -
Pulse Adrenaline Clutch Cable
By sparky in forum Parts DeskReplies: 1Last Post: 06-06-2010, 03:44 PM -
Stuck throttle cable
By txm123 in forum MaintenanceReplies: 8Last Post: 01-05-2010, 04:50 AM
