Results 1 to 1 of 1
#1 Error Codes 47 and 48 and Sidestand switch not cutting engine
- Jun 2016
- Wales
05-16-2019, 05:14 AMFault Indicator is flashing Error Codes 47 and 48 and the Sidestand switch not cutting engine when gear is selected, side stand light is on, the oxygen sensors are OK, voltage measurements show these are working, any idea what the fault might be, I think others also have the same fault.
QH250GY cutting out under load or high speed throtteling
By stacyc72110 in forum Dirt n' Dual-SportReplies: 1Last Post: 07-02-2015, 11:16 PM -
Engine Codes GY6
By motor in forum Ride Prep and Making TracksReplies: 0Last Post: 09-05-2013, 06:26 AM -
650Nk Error codes
By Wald0 in forum StreetReplies: 16Last Post: 07-30-2013, 03:16 AM -
pulse adrenaline, cutting out issue.
By mattybowen453 in forum MaintenanceReplies: 1Last Post: 05-16-2013, 10:59 AM
A Working VPN Solution?
