Results 1 to 2 of 2
#1 Slipping forward excellent reverse
- Aug 2018
- Canada
08-31-2018, 10:42 PM've got a tao tao 125 with a drive, neutral and reverse. Last week after it was rode for about 2 hours it wouldn't go forward reverse still worked. Put it up for about 2 days changed the oil then started working again. after about the second day my daughter was riding a few hours on and off it stopped again.If you lift up back tires they spin and if you hit the gas they'll spin faster. but if it's on the ground on pulls half speed in reverse and not at all forward. I would appreciate any help anyone could give.
#2 Re: Slipping forward excellent reverse
- Nov 2013
- South Africa
12-27-2020, 08:54 PMI had a similar issue with a 180cc Aeon quad bike. It would drive fine in reverse and Drive would just grind.....after taking the gearbox apart , I found that the bearings on the main sprocket shaft was shot. This mean that if in reverse the shaft was pushed up against the cover , but when in drive it was pushed down away from the gears. After changing all the bearings, quad is driving fine again.
Lifan 250GY-2 Cossack Slipping Clutch?
By Rockhorn in forum MaintenanceReplies: 8Last Post: 05-17-2015, 12:51 PM -
Great Ride Forward - Yunnan and SE Asia
By GRF_Hans in forum Ride Reports and MeetingsReplies: 81Last Post: 06-18-2011, 04:00 AM -
Great Ride Forward
By GRF_Pete in forum Welcome to MCM!Replies: 13Last Post: 03-16-2011, 11:13 PM -
clutch slipping CQ150GY
By gy150 in forum MaintenanceReplies: 3Last Post: 03-25-2010, 12:42 PM -
Excellent RR over on ADVRider
By DanKearney in forum Ride Reports and MeetingsReplies: 0Last Post: 07-28-2009, 03:06 AM
