Thread: Weird problem with Lexmoto XTRS
#1 Weird problem with Lexmoto XTRS
06-23-2019, 10:05 PMHi.
I've been trying to get the boyfriend's XTRS working and I'm running in to a weird issue. Basically it wasn't starting which I narrowed down to a compression issue; I replaced the piston rings and the compression tests fine.
Now it kinda starts but dies after a few seconds or if I touch the throttle. I believe the problem is with the carb since there's a good spark and compression is fine. While experimenting I found that for whatever reason, turning the idle mixture screw all the way in and applying maximum throttle allows the bike to idle perfectly fine and, with a little throttle, it will rev up but too much throttle will kill it.
It feels like a fueling issue but what exactly is a mystery; as far as I can tell there are no intake leaks, the carb is new and the problem persists with the old carb too, I've tried cleaning and replacing the spark plug but it makes no difference.
So if anyone could throw me some ideas on what to try to fix the problem that would be great because I am really confused at the moment xDSinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#2 Re: Weird problem with Lexmoto XTRS06-24-2019, 01:25 PM
Tune the valve clearance to spec 1st
#3 Re: Weird problem with Lexmoto XTRS
06-24-2019, 02:48 PMNice to see that you're still active :)
I forgot to mention that I've already set the valve clearances to 0.08mm on the inlet and 0.15mm on the outlet though I will double check those.
I just bought a can of carb cleaner so I'll give the carb another clean as a matter of course.Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#4 Re: Weird problem with Lexmoto XTRS
06-24-2019, 06:39 PMYeah it turned out to be water in the fuel tank lol
#5 Re: Weird problem with Lexmoto XTRS
#6 Re: Weird problem with Lexmoto XTRS
06-24-2019, 09:56 PMI was reading conflicting information on what they should actually be, thanks for letting me know.
#7 Re: Weird problem with Lexmoto XTRS
06-26-2019, 07:36 PMWell I completely drained the contaminated fuel and it seems a bit better but I think there's more to it.
The problem is somewhat intermittent; sometimes it will idle more or less fine and will rev up with a very gentle application of the throttle, other times it will idle rough and die as soon as any throttle is applied. Adjusting the choke makes little to no difference, if anything it makes it worse.
Pretty sure it's not an intake leak because spraying carb cleaner around the intake boot and carb has no effect, however periodically spraying carb cleaner in to the air intake makes it run better.Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
#8 Re: Weird problem with Lexmoto XTRS
07-07-2019, 06:07 PMIf it's of interest to anyone, it turns out the fuel tap was faulty and causing an intake air leak via the vacuum tube.
lexmoto xtrs
By drago in forum StreetReplies: 1Last Post: 02-10-2015, 01:57 PM -
Lexmoto xtrs 125
By lomi in forum MaintenanceReplies: 5Last Post: 09-24-2014, 04:40 PM -
Lexmoto XTRs 125, Headlamp problem
By les y in forum MaintenanceReplies: 0Last Post: 08-16-2014, 12:41 PM -
lexmoto xtrs
By weedod in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 05-19-2013, 11:23 AM -
end can for lexmoto xtrs 125
By xtrs125 in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 02-19-2013, 10:46 AM
