Thread: Noisy Rear Wheel Bearings
#1 Noisy Rear Wheel Bearings09-29-2020, 01:36 PM
Hi.
My rear wheel bearings have become noisy, but I can't find any play in them and there's no sign of overheating.
Would greasing the bearings cure the problem, or should they be replaced?Regards
Jim
#2 Re: Noisy Rear Wheel Bearings10-07-2020, 01:43 PM
Are the bearings in a sealed bearing set, or is there a grease nipple (probably unlikely on newer bikes)..? if you can get into the bearings then an application of appropriate grease might delay the collapse, but if the bearings are already noisy, I'd not risk a bearing collapse, and swap them out ASAP. May as well do all the wheel bearings (font and rear at the same time), to play it safe and mitigate any potential dramas or worse. I've experienced a noisy wheel bearing in a vehicle more than once and one time only just made it to a Suzuki dealership/workshop. The bearing in front wheel collapsed just as I turned towards the dealership/workshop driveway. Limped across the roadway into the workshop. Phew! I replaced all wheel bearings, since if one set go and the others are same mileage, then it's more than likely the others are soon to follow. YMMV
#3 Re: Noisy Rear Wheel Bearings10-23-2020, 06:06 AM
When you hear it already, turn into the next reliable shop or to your own garage. From my experience in China i would advise to find a shop that sells officially import bearings or at least german or japanese made in China. Local bearings are sh...t! (material, tolerances, cages) You can see it when you put a import bearing beside. A real bearing like e.g. a 6005 costs about 20RMB incl. VAT. Worth to invest it.
SWM RS500R, R1200GS LC
#4 Re: Noisy Rear Wheel Bearings
Huoniao HN125-8 Rear Wheel
By Yellow 14 in forum MaintenanceReplies: 0Last Post: 01-29-2020, 12:36 PM -
TMEC 125 Enduro wheel Bearings
By please_help in forum MaintenanceReplies: 4Last Post: 07-10-2019, 03:04 AM -
Wheel Bearings
By Sprocket in forum MaintenanceReplies: 6Last Post: 02-17-2012, 07:02 AM -
sinnis apache rear wheel problem
By everett5103 in forum Parts DeskReplies: 5Last Post: 01-19-2011, 12:26 AM -
By stacyc72110 in forum Parts DeskReplies: 1Last Post: 04-09-2009, 06:44 AM
