#1 Tires on Qingqi QM200GY / Qlink XF200C-Moto Noob
- Aug 2008
07-21-2009, 04:25 PM
I'm planning to change the tires on my Qingqi QM200GY / Qlink XF200. It's current tire size is 130/70/17 for the rear and 110/70/17 for the front.
My question is, can I use 140/70/17 for the rear or should I stick with the 130? Others are suggesting to get 140/60/17. I can't imagine why...
My choices are:
Duro HF918
An RX-01 by IRC tires
or, if I get lucky an
Arrowmax by Dunlop (GT-501)
Any inputs would be appreciated. No problem with the front, I would still be using 110/70/17 on it
Thanks
07-22-2009, 03:28 PM
Nutty,
The 140 should fit but you'd need to check the clearance between the tire sidewall and swing arm. Also with a 140/70 it should be a little taller than the 130/70...not just wider. That may or may not make a perceivable different in handling as a taller rear end would load more weight to the front.
A 140/60 may keep a closer overall wheel diameter closer to stock while giving you the extra width your looking for. Don't forget, the profile number is a ratio of width to height.
PS - Don't forget the Pirelli Sport Demon... These get some very good reviews and come in your size. Ninja 250 riders are big fans of these tires.
07-22-2009, 04:27 PM
Metzeler Lasertec and Kenda K671 come in the stock size. Try using the tire finder they have here http://www.bikebandit.com/ Easiest thing i've found. Just a couple clicks to find the right size, and it brings up a list of whats available. I wish all tire sites were that easy to navigate
C-Moto Noob
- Aug 2008
07-23-2009, 12:58 PM
thanks for the replies...will be posting updates on this
Qingqi QM200GY / Qlink XF200 alternative sprockets
By forchetto in forum MaintenanceReplies: 99Last Post: 02-10-2013, 05:21 PM -
Performance CDI for Qingqi QM200GY (Qlink XF200, STX, etc)
By forchetto in forum Modifications (Cosmetic and Performance)Replies: 62Last Post: 05-30-2012, 06:58 PM -
Qingqi QM200GY-BA (Qlink XF200) Iridium spark plug
By forchetto in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 09-13-2011, 08:42 PM -
Qingqi QM200GY (Qlink XF200) Raising handlebar height
By forchetto in forum Modifications (Cosmetic and Performance)Replies: 12Last Post: 04-16-2011, 01:13 AM -
Qingqi QM200GY (Qlink XF200) drive chain tensioner
By forchetto in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 02-23-2009, 06:04 PM
12-07-2025, 02:45 PM in Off Topic Discussions
