Thread: CFMoto 650NK Starter problem
#1 CFMoto 650NK Starter problem
- Feb 2017
- Argentina
02-23-2017, 02:53 AMHey everyone, Could I ask please advise on a startup fault as bike wont start on pressing ignition button, lights on ok, battery ok, fuses ok, wont start, just a no effect from the ignition button. when turning the key on there is no sound of fuel pump and no start up efi test routine showing but the other instrument lights and such are fine, Can anybody suggest a line of things I should be checking? I thought maybe clutch cut off or transmission cut off but theres no fuel pump or start up test which if im not wrong occurs first whether the clutch engaged or in gear anyway. has anybody had similar? should i be looking at ignition system or fuel pump??
Regards from Argentina
02-23-2017, 06:01 AM
Kill switch ?
#3 Re: CFMoto 650NK Starter problem02-23-2017, 11:39 AM
First thought - battery. Drained too low to turn over engine, but enough power to run the dash lights?
2nd thought - kill switch on or wiring in it toasted (as above).
3rd thought - Some random disconnected wire, check on bar switch gear and around starter motor.
#4 Re: CFMoto 650NK Starter problem
- Feb 2017
- Argentina
02-25-2017, 11:21 PM
CFMOTO 650Nk Mods.. so far
By CFMOTO Brad in forum Welcome to MCM!Replies: 6Last Post: 04-15-2020, 01:48 AM -
new levers for cfmoto 650nk
By pommie in forum Modifications (Cosmetic and Performance)Replies: 8Last Post: 07-18-2018, 05:53 AM -
GPR Exhaust for CFMOTO 650NK - PROBLEM with GPR Product and Customer Service
By JC 3D in forum StreetReplies: 2Last Post: 09-23-2016, 05:11 AM -
Which tires for CFMOTO 650NK/TR?
By ZMC888 in forum StreetReplies: 31Last Post: 05-31-2015, 11:00 AM -
New CFMoto 650NK blog x2
By ZMC888 in forum StreetReplies: 90Last Post: 03-29-2014, 06:38 AM
