Just assembling my bike. Noticed the hose that comes from bottom of Carberator is not connected to anything, should it be?
I may be wrong, but I think I've read here- it shouldn't be. That it's the bowl drain hose...
awesome thank you
That is just plain wild that you should post about this. I have been riding my bike for some 3740 miles and I just now (yesterday) saw that this line was not attatched to anything.I went over the bike with a fine tooth comb the day it arrived in the crate,and never noticed it..and i was just about to post a question about this line myself. Thanks for reading my mind.. mixmaster..and thanks for answering it as well xetaprime.:icon10:
:goodtime:
Can anyone help me please with the light wiring - tank is off; I found the dark green wire that is connected to the blue and white coming from the front - if I read all the thread information right on this, I should also find a blue white wire coming from the rear of the bike and connect the 2 - problem I have is I don't see this wire frim the rear - should I unwrap all the wires way back into the rear - will I find it I do that?
Don't know if this will help
Found my headlamp issue.
First photo Blue/Yellow from left controls (really blue/white) was connected to a deep green line to the diode bridge (extra rectifier?) (photo 2). With power on (key on) blue/white to dark green dead. Blue/Yellow on right Illuminating switch (blue/white actually) showing power but connection housing under tank was not to be found.
Found it dead ended in the wrap half way between illuminating switch and connection housing . Disconnected the dark green from the blue/white and connected the two blue/whites together (photo 3). BINGO, headlamps ON, dimable left switch & able to turn off right switch! I'm going to wrap dark green end & take a ride after I put this mess together.
I never did have headlamps. The harley guy (earlier thread) that yelled over to me that my light was dim, I thought was the height adjustment of my lamp. Safety checks during break in failed to see the big bulb not working.
from page 132
I think I read also something about using a black wire connect but haven't found it again. Good luck!
Thanks! I saw this but stiil struggling to find the second blu white wire - probably burried deep - will try to find it next
Thanks - I found one blue white wire but don't think it is the right one - this one ends together with a yellow wire in a connection (small white plastic connector with a black plastic cover on the end). I will look deeper down...
