I'm going to make the plate and remove all the plumbing like I did on my old DF.
Attachment 12320
Use the removed piece as a pattern to make the plate out of 1/8" or so aluminum plate. Paint it black. Put a cap on the vacuum port. Easy peasy.
On my old DF then I moved the ignition key switch to the place were the pump was. Kinda cleaned it up a bit. I don't know if this will work on the new model.
Attachment 12321
any chance you could make an extra and send it out this way for a little $?
Bobthebobber
PM me.
5 Attachment(s)
My DF arrived today and I met the delivery truck in town and transferred it to my truck. No way could he have gotten up my steep driveway. Very little clearance between the rear wheel and the tail light wiring so that is the first thing to fix.
She looks good.
Attachment 12342
Shop is getting a little crowed.:lol8:
Attachment 12343
Looks like I can increase the clearance between the tire and tail light wiring by putting a spacer here. That will move the bottom of the rear fender aft and therefore raise the rear of the fender. I already put in a small spacer but need to get a longer bolt tomorrow for a longer spacer.
This thread is kinda all over the place as long as it has to do with one the 250 OHV Bobbers whether a CCW Heist or a DF 250 China girl. That being said, What positive effect does taking this EGR tube or what ever is out and covering the hole with a plate ? Is it just to simplify the engine bay and clean up the looks ?
4950cycle
Should make the engine run a little cooler, reduce popping on deceleration, but otherwise just cleans things up a bit as you mentioned.
This thread is about the DF not the Heist. There is a separate thread for it.
BTW, the CCW Heist a also a China girl.
