alleykat
Has everyone had the fuel leaking problem at the gas tank mount ?? Kinda scary. Should these be "fixed" right out of the crate?
i haven't had any leaks in my tank whatsoever, i think the leaks happen when you take off the tank and then put the nuts back on too tight and crack a weld. i've never removed my tank, and thus have not had a leak.
hooliganboy
I agree, removed tank several times, but because of prior warnings (this site) I never torched down beyond 10lbs. No leaks, but fuel range, vapor lock & ozzing stains from cap, I intend to replace tank. Trying to find a 3+ tank that resembles design.
How/where did you guys have the inspector put your state inspection sticker on this bike?
hooliganboy
Ok, thanks. I was trying to decide if I should "jack" with it or not. I was leaning toward not messing with it at first and causing more problems, LOL.
alleykat
they don't put the sticker on the bike itself, they just fill it out and stick the clear plastic back over it and you keep it with your paperwork. i just stick it in my wallet with my insurance and registration whenever i ride.
alleykat
I made a small lexan square drilled a couple holes in ot and mounted it onto the side of my plate.worked great and the inspection guy told me I should make a bunch of them and sell them. Here in Texas You DO need to display your inspection decal in the open next to or below the plate. I suggest you hit home depot for something to fab a small square for yourself.
I cut a piece of thicker sheet metal to the size of the licence plate , with a "square" sticking off the bottom of it for the inspection sticker , painted to match frame , bolts to bike with plate
Ok...I keep reading posts concerning gas tank leaks on this bike. I am about a week or two away from putting one of these on layaway. Are you guys getting leaks because of taking the tanks off and putting them back on or do they come that way from China? Is it a defect in the design? I never plan on taking mine off so will I be alright? I would like to know BEFORE plopping my money down. Thanx in advance.
Preacher
I had a leak and it had never taken the tank off at all. But....we have very bumpy roads around here in Houston.tough riding for a rigid bike.You can feel every nuance of the road.It rattles your teeth .I figured with all the bumps and bangs the bike gets in my travels it just tweeked the tank brackets enough to crack a weld.which it did. No worries.I removed the tank..jb welded both brackets and did as barnone did ..sleeved the studs,and secured it with nylon threaded nuts and did not clamp down tight but snug. no leaks thus far.I intead to change the tank eventually..when I find the right one for the right price,probably at a swap meet as I am after that RAT bike look. Listen these bikes are a tremendous buy..but you do get what you pay for.It isnt a Rolls Royce,and things are gonna happen,but again for the cost,and the enjoyment...I am fully satisfied with my purchase,and I just fix as I go.I have had some experience fixing and switching these chinese bikes for the last three years as I have been on a chinese scooter for that time and always having to do something to stay on the road..but it is small stuff..nothing mechanical from the motor..just little things.Lots of plastic stuff . For instance,last night I was checking my oil..and the chrome plastic top of the dip stick popped off while I was unscrewing the stick...nothing broke,just the small amount of glue they use to mate the top and the stick had seperated from the joint.easy fix,superglue...now works fine.But you are gonna run into these things with this bike.But again...for the cost..nothing to cry over,and something to expect.
I was riding home one night,and my kill switch knob flew off...the little screw inside the harness assembly was not tightened enogh..and it is not something you would think about tearing the assembly apart to tighten..so i just didn't get upset.then a few days ago..my brake switch on the bars went out..brake light work with the foot brake,and touching the two wires together at the bars made the lights work so it was the switch.I called scooter depot,talked to a tech,and three days later..(last night) a box showed up with a new switch,and they sent me a new harnes assy with the kill switch knob on it..the whole assemby..not just the knob.No charge to me,I paid the extra warranty on the bike(I recomend this as it covers it all pretty much for a longer time) and worth the extra cash.(experience from the scooter again). so I am good to go.
I love this bike.It is what i have been looking to ride for a long time.Small cc and cool looking.Simple to maintain,and just plain cost effective.What more could you ask for.
I will recomend this bike to anyone,regardless of any of the small issue that come up.they are nothign to be upset about,and the cost is way cheaper than it would have been for a big brand name bike and any repairs done on them.This is realy an old school way to ride,you ride..you maintain..the heck with dealerships and flash. Every motorcycleist has a tool bag,cause every bike big or small breaks down..so this bike is no different. just cheaper to ride,and to me...cooler than anything else out there.
Preacher
Bowtie did a good job of answering your questions but may I add a few ...
I would say that the tank leaking issue is a defect in the construction of the tank. The rear studs that attach the tank to the bike are made in such a way that over tightening or rough road riding might cause a leak.
To say that you will never take the tank off says to me that you are an inexperienced motorcycle user because sometime over the life of the bike you will have to take the tank off.
With that in mind, perhaps you should not buy one of these Chinese bikes.
These Chinese bikes should not be bought by someone expecting Japanese bike quality.
Thank You BTwagon for your in depth answer to my question. And to others thank you very much I am VERY familiar with Chinese bikes owning two scooters. I am very experienced with "jury rigged" fixes, for example the mirrors on my 150cc that are legendary for not staying put. I have never owned a Japanese street bike so comparing the two would be pointless. I can handle most issues with this bike and those that escape my prowess will be handled by a very experienced Chinese cycle/scooter tech that also happens to be a friend of mine. I have known how to ride motorcycles longer than some of you have been alive but they were dirt bikes. I only wanted some info on the gas tank and thanx again BT for your intelligent response.
Preacher, you'll do fine, send photos when you get it.
Alleycat, do they still show 2010 as model year or '11?,'12?
Let's see your machine (out of the crate)!
Preacher,
Sorry I hurt you feelings but when someone says"I never plan on taking mine off so will I be alright? I would like to know BEFORE plopping my money down. Thanx in advance." then that is a good sign of inexperience regarding motorcycles.
Good thing you have a "very experienced Chinese cycle/scooter tech that also happens to be a friend of mine."
What's the big deal about the layaway?
BTW, I built my first motorcycle at age 12 back in 1954.
Thanx GR. It has been ordered today in gray (matches my Helmet haha)
bowtiewagon
I archived this in my Email so I can remember what to watch out for. I also passed it on to my friends at Heluva Scooter here in Oldsmar and they were very thankful for the info. I know you guys are not fans of dealers and usually neither am I but The owners are friends of mine so I get lots of perks like free helmets and Bikes at Cost etc. I will post pics and video when I take possession in about a month. I cant wait! Thanx again.
GUN ROD
Mine shows a build date of Dec 2010. I haven't had a chance to get back to it yet, still have flu-like crap.
Working all day and "crashing" when I get home. Maybe this weekend...
What grade of gas are you guys using?
87 octane works fine for my DF CG250 engine.
Well folks,I had an interesting ride yesterday. I hit 3rd gear and bam the clutch cable snapped..I did not panick..I basicly rode the bike in third found a less travelled street to turn onto, and rode the throttle down until it stalled to a stop. Had to have my bro-in-law pick me up with the trailer.Gonna call the scooterdepot today If they are open and get a replacement sent...but I am also gonna look for another cable to use instead as i feel that this is an unacceptable defect. I only have 800 plus miles on it..and there truly is not a reason why the cable should just snap at the tip like that. Freaky moment for sure. Very disapponting as well ,as the weather these past two days were ment for riding..since we have had mostly gloomy weather all weekend, an now i cannot ride. I suggest you check you cables on a regualr basis and maybe even look into replacing them to be safe.
bow,
Did the cable actually break or did the end come off? Can you take a photo of the broken spot?
Thanks,
bow,
Thanks,
I think it was just the tip that popped off..but I have no way of making sure cause in motion the tip and what may have been left of it was lost on the road. The end of the cable was a little frayed,and untwisted. Maybe the term "snapped" wasn't the correct word to use,but in the heat of the event,it seemed to be the best choice.
bowtiewagon
Back in my old days with British bikes and Harleys, it was not unusual to have the end pop off the clutch and brake cables. These were required in your tool/spares kit.
http://www.jpcycles.com/product/520-...FQ5T7AodQUtwpA
A good write up on how to repair your clutch cable end using JB Weld at
http://www.chinariders.net/modules.p...ighlight=straw
That is some great stuff there barnone. Got remeber that for the next time. I called the scooterdepot and should have a new cable within a couple days.
On that second link with the JB weld repair.You can do the same thing using copper tubing for an ice maker and solder.I've seen it done with lead,silver,and tin solders.
Looking at Headlamp assembly change, can I jump from our 12V/35W/35W to a 12V/60W/55W without changing wires & related system behind?
bowtiewagon
wow, scary stuff man. at least you had the right mind to do what you did some people would panic and not know what to do.
GUN ROD
Two different bulb bases. As always, the wire size is marginal. This is the proper way to convert the wires to handle any larger Watt bulb.
http://easternbeaver.com/Main/Produc...s/h4_kits.html
gun rod,
have you looked into LED headlights which give higher light output without requiring more watts?
Thank you both, I ruled out H-4 (halogen) lamped assemblys due to an obvious overloading wires (80/90W) without relays (see Mailman's link). LED are interesting but no traditional designs seen & out of budget. Dennis KIrk offers a black 7" traditional assembly that has a park light with high/low normal 55/60 bulb. Installation appears simuliar to ours.
Ordered today. Will advise.
Barnone, how is the tank going?
GUN ROD
Nothing done on the tank so far. I will have to cut off the existing tank mounting tabs so I haven't rushed into it.
http://i182.photobucket.com/albums/x...911280x960.jpg
One of the gas cap openings is a dummy.
http://i182.photobucket.com/albums/x...901280x960.jpg
Suppose to be 3 plus gallons.
http://i182.photobucket.com/albums/x...891280x960.jpg
Under side of the tank. Manufacturer recommends using Kreem to coat the inside of the tank.
