Re: chain info - loose ends
tidying up the thread title...
All I know is that you do need to check it doesn't eat the 'o'rings, the one I use is called INOX mx9 NO CHUKKA and the blurb on the side says 'sticks like shit! and it has 'special tackifiers' ... which scientific explanation encouraged me (only in Aus would you see that!). They recommend a chain clean using, yup, their brand cleaner, every 3 lubes. It doesn't say it is OK for 'o' rings on the can but the I checked the web site and indeed it is 'o' ring safe. I doubt you will find this brand but just look for that info.
NOTE: do not spray this type of stuff in a closed space or near any equipment with live electricity, switches etc. as a spark can cause fire! That's a jape warning, not an official one but common-sense should apply.
I could only go through the posts individually to delete thread titles referring to old thread Jeff, haven't worked out a way to do that as a batch yet, will look further next time I have to do a batch move of posts like this! Another anomaly is that I have to do post moves page by page as post selections don't hold for more than one page at a time. Not to worry, it doesn't hurt or take too long and we get there in the end. one day, after talking to CC, I intend to go through a lot of threads and put them together in sections under 'maintenance' for example. Some get out of place quite quickly. The biggest 'moan' I get from members apart from about my own behaviour is that the search function often fails. I will have to look at 'tags' and 'keywords' in the forum admin. blurb to get a better handle on that. This forum format does work better than most I know of and use. Any ideas on this, or similar matters, PM me or post in the http://www.mychinamoto.com/forums/fo...nd-Suggestions. Hmm, now I am hijacking the hijack.
jape
... wash in kerosene /paraffin and then cook them in hot oil! Back then a good chain was good metal and lasted ages...
This?
http://farm3.static.flickr.com/2100/...121bc1463d.jpg
I read similar story in "modern days" when that "oldie" disappear in market from somewhere:
Stir chain in molten Moly Grease (Chinese equivent). Most important thing is let that sh** seeps into roller surfaces.
Let that s*** cool & solid again. (This sh** can use again) Pull the chain out. ***no solvents, rags ONLY *** Wipe the surface thoroughly.
Fit the chain on bike. Spin back wheel. Spray entire chain with WD40. Wipe wet WD40 off using clean rag. *** WD40 is to protect outer surface. DON'T let it seep into the roller surfaces ***. Ride & enjoy.
Cleaning using WD40 ONLY as above step every week. NO oil or chain lube. *** NO thin oil seeping inbetween the roller surfaces displacing the grease. DON'T attracting dirt ... that f***s outer of chain. Grease will find its way out!!! ***
Clean thoroughly in solvent & "redo" when grease used up after 4-6 months.
I've been using a can of this - seems ok, as far as I can tell, but I haven't run either of my JH600s through any streams or seriously dusty conditions. I ran my XTR 250 through some ugly stuff and after the bike dried off, the chain seemed to have remained somewhat lubed. I applied some more spray lube and it cleaned it up reasonably well. I also use a little tube of heavy gear oil that I apply sparingly and the two components (lube spray & gear oil) don't seem to mind each other.
I go through a lot of this stuff so price is a concern of mine.
