I'm having a lot of problems adjusting my valve clearences
Hi, I've tried several time to adjust my valve clearances and had no luck, every time I do it my valves will make a loud ticking sound when the engine is running and the performance is slightly degraded. I am unsure if I am rotating my engine to the correct position; when I align the mark on the flywheel with the other mark on the crank case cover there is no free play in the rockers whereas when I rotate the engine a little further the rockers lift up a little more and there is some free play so at which point do I adjust the valve clearances?
I don't think my engine is in any danger because I have done a 100 mile road trip since I adjusted the valves which involved hard acceleration, red lining and full throttle for extended periods and the engine didn't explode but I want to be 100% sure on what to do before I adjust them again.
By the way my engine is a K157FMI which is used by Sinnis 125s, pulse adrenaline and many more.
Re: I'm having a lot of problems adjusting my valve clearences
The rockers should be loose when you find top dead center correctly.
What China V said. Also, look into the cylinder with a flashlight. You should be able to see the top of the piston.
Thanks for your replies. So do you think that the TDT mark on my flywheel is wrong? The mark goes beyond the inspection hole before the rockers are loose.
I'll do the piston thing tomorrow when it's not raining.
I don't think that it's wrong, just that your valves are too tight. Use the mark and visual confirmation of the location of the piston to start. Then adjust your valves. Check out V's post here; http://www.mychinamoto.com/forums/sh...ighlight=valve
i think you are looking at the firing mark not the tdc mark
firing mark will be about 20 degrees before tdc
I'm pretty sure that my valves are too loose since they are clicking and I've read on several forums that valves that are too tight won't click. There is only one mark on ym fly wheel and it does seem that I have to rotate it roughly 20 degrees before the rockers become loose so maybe I only have a firing mark which seems weird to me.
I adjusted them again this morning and it seems a little better but the clicking did get louder as the engine warmed up as usual. I'm not entirely sure that the clearences that I am using are correct; Sinnis told me that they should be 0.08mm and 0.13mm but someone on this forum said they tried 0.07mm on both and it was fine so I'm thinking that maybe I'm getting the exhaust clearence wrong. I was thinking about just going for a trial and error method and gradually tighten the exhaust clearence until the ticking dies down, is that a good idea or not?
pushrod valves "click" period
live with it
u tightn enough to make em not "click" and you will break something
but there life span far exceeds normal bikes with far less upkeep
there are still CG 125's (old honda motor alot of motors are cloned from) that are still running
myself experianced with old chevy pushrod V8's , had no issues = find top ded center adjust so barely "ticks" by hand , absolutly no measurments or tools other then my trusty adjustable wrench XD
an oil cooler will keep temp down to keep the "ticking" to a minimum , but mine as well sounds awsome at start up and ticks like crazy after 30 miles on highway , nature of our beasts
spencer2004's bike is OHC Suzuki clone
spencer2004
According to the searching I've done the clearances should be from .08mm to .13mm for both intake and exhaust. Those numbers are for the Suzuki GN125 engine. That is the engine that yours is based on. If you are having trouble finding TDC It really helps to have someone watching the piston while the motor is being cranked through the access hole. You should find a corresponding mark on the flywheel when you see the piston come up to TDC.
Ok I was on the wrong stroke when at TDC, on the correct stroke it became very easy to turn the engine and I have been flying past the mark without even noticing. I've adjusted the clearences again at the correct stroke and triple checked both clearences and I'm still getting the ticking!!!! I even tightened each adjuster down by about 1/4 turn after that and still got the same problem. I need more suggestions please guys.
By the way I've noticed that when the engine idles it runs a little bit inconsistantly; most of the time it will run like normal and every 10 seconds it will run a little quieter and smoother for about 1/2 a second. Also before I messed up my valve clearences I would get a wonderful roaring/farting noise comming from my air filter while accelerating but it isn't as loud any more so I assume that less air is getting into the engine than before.
spencer2004
Ok I was on the wrong stroke when at TDC ... I need more suggestions please guys.
Been there, done that, got the oily t-shirt :icon10: Don't feel bad, it is a common mistake.
I am assuming your oil viscosity is ok? Not too thin?
Also, are you sure the ticking was in the valve train? We all tend to first assume that ticking is the result of valves needing adjustment. Investing in even a cheap mechanics stethoscope can help isolate where it is coming from. If you discover that the ticking is indeed coming from the head/cover, it might not be an out-of-whack lash, but rather excessive play in another part of the rocker assembly.
I don't know your engine, so how does the oiling system work? Is it possible to remove a cover and run the engine to watch/hear the valves operating? Or does the engine just have an inspection/adjustment plate/cover?
Lots of little bits and pieces in a valve train that can make the ticking/tapping noise if there is some wear/free play.
It's been about 1550km since my last oil change so it's probably due for a change, the oil is at the correct level and I am using the reccommended oil for my bike (10w-40) however. My engine only has inspection covers for the valves, is it safe to run the engine with the covers off? It is starting to look like something other than the valves is causing the noise but it seems odd that this would start right after I adjusted the valves unless if the incorrect adjustment caused it. I don't know how my oiling system works but oil is reaching the valves with no problem as far as I can tell. I tried listening to the engine with a screwdriver pressed against my ear and the noise was louder at the top of the engine and loudest at the intake valve.
Even though I have a 200cc, both engines are made by the same company, Qingqi. That's why I suggested ChinaV's post. I made a few mistakes the first time I did my valves. The first is I used the wrong feeler guages. I was using standard guages but using the metric numbers...or the other way around. Anyway, they ended up too big and the bike ran like crap. The second mistake was I used straight guages instead of angled. The area is very tight as you now know. It takes a few tries to get it right as V said in his post. At one point I was thinking about dropping the motor out a bit to get at the front but I got it done. It really does help to have another set of hands here. Also, as DanDaMan said, there will always be some ticking sound coming from these small thumpers.
I figured it out in the end. Most sources says to adjust the valves so you get a loose fit with the feeler gague but I read somewhere else that that is crap and it should be a tight fit so I tightened the valve adjusters a little more than I usually do and the valve noise went away.
spencer2004
And now just wait till your valve seats start to burn.
I mean, this is NOT correct and might lead to larger engine damage.
There are imo NO motorbike engines with ZERO gap at cold engine.
The gap is there for a purpose, something else must be wrong causing the ticking!
No what I ment was when I put the feeler gague in and adjust the valve clearence I go with a tight fit instead of a loose fit.
Try with proper fit. Maybe you understand incorrectly how tight or loose you should be feeler gauge while adjusting gap. This is a subjective feeling, and it is difficult to express in words.
Man, there's no need to complicate things. Stick to the service manual recommendations. If you hear ticking, look somewhere else in valvetrain (I don't know... maybe chain tensioner...) besides the valve clearance.
