rear sprocket needeed for adrenaline pulse.
Can anyone tell me where i can get my hands on a replacement rear sprocket for adrenaline pulse 125 08 model? Have tried two companies so far and both have required the dimensions and how many teeth. I am also unsure of the correct amount of teeth of the original. I have a 16 tooth front sprocket ready for replacement. Without going too mad on messin with gear ratios e.t.c think it's best to stick with original rear set up.
Thanks D.
Re: rear sprocket needeed for adrenaline pulse.
Hi Dan. Have a look at previous posts, here: http://www.mychinamoto.com/forums/sh...=rear+sprocket
and here: http://www.mychinamoto.com/forums/sh...prockets/page6
The last one goes on a bit. Like Leo Tolstoy's 'War and Peace'. :eekers:
The bike importers sell rear rings in 48t and 51t, but I suppose you are looking for other ratios or parts from other after market suppliers, whom I myself have found what you have said, but at least you have been asked for dimensions, me, I just get; what bike mate ?, a what ?, hahahahaha, no, we don't do anything for them. But if you supply the dimensions they ask for, at least you have a helpful vendor, who actually wants to make a sale.
Perhaps you could supply the vendors with the bolt pattern dimensions and centre hole dimensions and say, what have you got that fits the dimensions, that will tax them, someone who asking based on specifications and dimensions, not bike make and model.
16 t front sprocket for a Pulse Adrenaline, is your engine output shaft multi splined, I think 19 splines, if so, where did you get the sprocket ? I got a 16t recently from a supplier who told me it would fit, but it turned out it didn't, as it was for a six splined output shaft, contacting the supplier, he told me I had the cheap low power suzuki based motor and it won't fit, most Chinese bikes have the stronger six spline, based on the Honda motors. My annoyance was being told the sprocket would fit and when it didn't, my ride being more or less insulted, as a result, I will not be dealing with that company again, as my belief is they did not know what they were talking about, they assumed a part would fit, they did not check before flapping their lips.
Hi Dan
There are two default rear sprockets for the Pulse Adrenaline, and the one you want will depend on the version of bike you have. The rear drum version used a 6 stud pattern 48 tooth sprocket (428-48t) and the rear disc version used a 4 stud pattern 51 tooth sprocket (428-51t).
Try using www.chinesemotorcyclepartsonline.co.uk who can supply all the parts for the Pulse and other chinese bikes from the UK. They also have different size sprockets should you wish to alter the gearing ratio, all you need to specify is whether its a disc or drum version.
I noticed you mentioned having a 16t replacement front sprocket. Is this what you had on it previously? As i thought the standard size was 15t.
Sparky
Dan
Thanks D.
Hiya, 16th front and you want 38th for the rear, Sounds like it may climb tree's but it wont it will be very fast and yo are gonna want the kamikazi coil(single spade) & cdi(4into2) for gy6 engine both can be got off ebay and I wouldn't bother with LLexeterthey are expensive my mate own's this one: https://www.pioneernevada-parts.co.uk/zenshop/ and tell him Frisco from my forum sent you?
sparky
Hi Dan
Try using
Sparky
Hi
I have a Drum version of pulse adrenaline 125 and it has a 51 teeth rear sprocket (428-51T), mounted with 6 bolts.
Cheers
superfamous
Hi
Cheers
You may e-mail JT sprocket (w /measurment) to find a compitable one---JTR809 seems fits . Then u can source it "cheap" locally, If that fails, there's option bought it from china.
51t http://item.taobao.com/item.htm?id=5358289631
48t http://item.taobao.com/item.htm?id=5048199451
humanbeing
Hi Humanbeing
As I told You I have a drum version of pulse, but I'll upgrade it with a rear disc. I have to change the rear wheel too.
As far as I know the rear sprocket is mounted with 4 bolts in the disc version, am I right?
Can you tell me a URL of taobao where I can buy the right one to mount in the disc version wheel? I thinkin of using a 45 or 48 teeth sprocket.
Thank you for your help because try to understand chinese is pretty hard for me.
Mario
jtsprockets have had an update and allow you to search for your exact bike just rebranded, on the site they call the bike kreidler aka pulse etc etc
http://www.jtsprockets.com/100.0.html?&L=0&id=38
