Page 624 of 627 FirstFirst ... 474574604614622623624625626 ... LastLast
Results 6,231 to 6,240 of 6265
  1. #6231 Re: Dong Fang DF 250 RTB Bobber Information
    C-Moto Not-so-Noob
    Mar 2017
    Illinois
    Quote Originally Posted by ben2go View Post
    I have been doing wheel work since I was a kid, about 30 years. I had no other choice but to repair my own wheels. There's no problems with ringing spokes and tightening them. It takes more than snugging up a few spokes to pull a rim out of true. There is more than one way to do things. If my way is wrong, then 90% of all spoke wheels are at risk of blowing up and killing everyone around. The dealerships and shops use the same technique as I to tighten a few loose spokes. Indepedent shops are where I learned how to repair wheels. These are China bikes. Most of them are not true from the factory. It was uncalled for the way you responded. We try to keep it civil around here.
    I don't care about your 30 years of backyard wheel work and frankly I don't care about hurting your feelings! There is a right way then theres the backyard mechanic way! Some of the "helpful" information is absolute trash! If your gonna tell somebody how to fix something at least tell them it's the shady way of doing it! Have u forgotten it's 2017 and they do not make rims like they used to! In today's world lighter is better and I know for a fact the rims on these bikes are very easy to bend and retard the true! I will stand strong on my opinion of needing to do it correctly! Go ahead and follow instructions based on saving money and see where it gets you!
  2. #6232 Re: Dong Fang DF 250 RTB Bobber Information
    Senior C-Moto Guru barnone's Avatar
    Dec 2009
    SWFL WNC
    Get something like this wheel stand to check trueness and balance. Just clip a pointer on it for trueness.
    https://www.harborfreight.com/motorc...and-98488.html
    Don't forget your 20% off coupon.
    Also a spoke torque wrench is helpful.
    Vince
    2015 Ural cT sidecar
    2014 Honda CB1100 Custom
  3. #6233 Re: what this bike should have been from the start
    Dec 2009
    SWFL WNC
    Quote Originally Posted by MidMoMan View Post
    I've not removed the rocker cover, but am thinking it might be possible that my engine is a 165 & 167 cobbled together? The 165fmm (CB250D-G) is listed as a camshaft upward but mine does not have the rocker cover to house the camshaft & chain. So, I bet you are correct. My bottom end is stamped 165FMM.
    My 2012 DF's 167FMM engine looks the same as your DF's 165FMM engine.
    No telling what the Chinese will do.
    I painted my valve cover.
    You need to pull the valve cover and check your rocker arm clearances before you ride it too much.
    Vince
  4. #6234 Re: what this bike should have been from the start
    C-Moto Not-so-Noob
    Mar 2017
    Illinois
    Quote Originally Posted by barnone View Post
    How did you get your ignition where it's at above the rocker cover?
  5. #6235 Re: what this bike should have been from the start
    C-Moto Not-so-Noob
    Oct 2017
    Ashland, MO
    Yeah, here is the proof in the pudding. Go figure. Thanks!
  6. #6236 Re: what this bike should have been from the start
    Dec 2009
    SWFL WNC
    Quote Originally Posted by slightwinner View Post
    Just moved it to where the air injection system was mounted.
    Vince
  7. #6237 Re: what this bike should have been from the start
    Dec 2009
    SWFL WNC
    I bet your engine is a 167FMM and stamped 165FMM for some reason like EPA approval?
    Here it states that the engine is 229.2 ccs which is the167fmm displacement.
    http://www.df-motor.com/product_show.asp?id=675
    Vince
  8. #6238 Re: what this bike should have been from the start
    C-Moto Not-so-Noob
    Oct 2017
    Ashland, MO
    https://www.alibaba.com/product-deta...4a8239deBrjKN7
    Has anyone seen this bike for sale by a US distributor? I really like my China bike and would love to get this one in the 300cc. It has about the same wheelbase as our DF and I would think would make more than enough power to go highway speeds.
  9. #6239 Re: what this bike should have been from the start
    Senior C-Moto Guru culcune's Avatar
    Apr 2008
    Yuma, Arizona (the 3:10 left me here)
    Unfortunately, the US distributor have only received EPA/DOT approval for the 229cc Zongshen-OEM engine. They have the certificate for all their bikes across their lineup that use this engine. On the EPA site, they list their enduros, the bobbers, the cruisers, and their sporty bike etc. on the same certificate! They got their money's worth
    The downside is we won't be seeing a larger engine anytime soon here in the US.
  10. #6240 Re: what this bike should have been from the start
    Dec 2009
    SWFL WNC
    culcune,
    You seem to up on all the Chinese engines. Can you explain what appears to be a 167FMM engine on the newest DF250RTB being stamped as a 165FMM? Thanks
    Vince
  1. DD350E-2 Bobber
    By xacarrere in forum Manufacturers and Importers
    Last Post: 08-28-2015, 12:03 PM
  2. Bobber Bikes
    By Geronimo in forum Sidecars
    Last Post: 07-20-2011, 05:02 AM
  3. Help ID this customized chinese bobber please?
    By fonzerelli in forum Street
    Last Post: 06-12-2011, 05:00 PM
  4. my 2nd 16 inch bobber
    Last Post: 09-13-2010, 11:10 AM
  5. JH600B Information Wanted
    By blazeafar in forum Welcome to MCM!
    Last Post: 04-29-2008, 12:38 PM
Tags for this Thread
View Tag Cloud
