Thread: DF250RTB Chopper
Results 11 to 16 of 16
#11 Re: DF250RTB Chopper05-18-2011, 10:12 AM
Acoording to countyimports.com, these two bikes are the same thing except the rear fender. I can tell the gas tank is a little different too and the seat, but I think they are the same thing underneath.
The bobber has the same dimensions too. (70 inch wheebase and 26 inch seat height). I am confused why the choppers are called 3/4 size and the bobber is called full size due to these dimensions if they are accurate. The bobber does look bigger in the videos with people riding it though.
#12 Re: DF250RTB Chopper05-18-2011, 12:44 PM
bigger wheels on the bobber and the forks are different giving the chopper a smaller appearance. the frame is basically the same
Gardo northern NJ/NYC
CCW tha Heist tha Widow
CCW tha Misfit (tha Wraith)
50 State legal and Worldwide
CCW Heist Riders
#13 Re: DF250RTB Chopper
#14 Re: DF250RTB Chopper06-07-2011, 12:42 PM
this explains why:
Bobbers are related to choppers in that they both take a minimalistic approach This includes the characteristic rigid frame and shortened "bobbed" rear fender. The main difference is that bobbers are typically built around unstretch frames and stock fork rake, while a chopper frame is often stretch out and welded into shape with enlongated forks.
#15 Re: DF250RTB Chopper06-07-2011, 12:44 PM
so if you use same frame it's already a full size for bobbers but still 3/4 size for choppers.
#16 Re: DF250RTB Chopper
- Aug 2011
- texas
08-29-2011, 10:55 PMbought my chopper DF250 CHA/B thru killer motorsport cause they licence and tag it for ya
only prob Ive had was
unable to find same size tires if needing a replacement - will use moped front and car low profile rear if it comes to it
extreamly low gearing , added a 17 tooth front brought it to 65 top speed but engine still has more to give (holds it like a champ) (I'm 150 lbs bike only 240 lbs) actually concidering a 33 tooth rear :p ( 1.9 ratio would bring my top end to about 80 allowing "cruising" at 70-75ish) 20" tall back tire requires extream gearing
and rectifier dimming lights on high revs and popping bulbs on returning to low revs (new one on order)
I'm 150-160 lb 6'5 male austin texas area only minor road grades, needed to extend forward controls 1 full foot and
currently working on fabricating a split dual air ram (2 90degree angles) to feed the bike at highway speeds , and a sissybar backrest
nearly have 500 miles on bike already 80% of that is 60-65mph highway miles
run good seems reliable , only piece of advise I have is if you get yours and headlights dim when ya rev it , order another rectifier (to avoid popping running light/headlight/taillight/turn signal relays every time you ride it
Chopper china ¿¿??
By xacarrere in forum StreetReplies: 22Last Post: 08-28-2012, 02:18 PM -
Hi-Bird QH250 Chopper!
By CrazyCarl in forum StreetReplies: 21Last Post: 05-28-2012, 08:13 PM -
Thoughts on chopper...pd-250
By bighabeeb in forum StreetReplies: 23Last Post: 03-14-2011, 03:56 PM -
Eeaglets Chopper Team from Poland
By ArtSpire in forum EuropeReplies: 2Last Post: 09-18-2010, 05:25 PM -
Praise the Lord and Pass the Hubbless Chopper...
By CrazyCarl in forum Off Topic DiscussionsReplies: 29Last Post: 02-06-2009, 09:35 AM
