Thread: Lighting error?!
Results 1 to 8 of 8
#1 Lighting error?!
- Jun 2013
- Leeds
12-22-2013, 10:57 PMHi, just wondered if not having a bulb in my headlight would stop all other lights working on my bike?!
Or is there other issues causing this?
#2 Re: Lighting error?!
- Nov 2010
- Beijing
12-23-2013, 03:09 AMIt shouldn't affect other lights. As far as I know they normally all have their own closed circuit, it's not like those old fashioned Christmas tree lights where you turn one bulb out and all lights go out.
Kawasaki Versys 650
Shineray X2
#3 Re: Lighting error?!12-23-2013, 11:00 AM
It might be mass (=earth) related.
#4 Re: Lighting error?!
- Jun 2013
- Leeds
12-23-2013, 06:16 PM
#5 Re: Lighting error?!12-23-2013, 10:49 PM
If no electric starter, normally one each.
The red as POS to all systems, the black as NEG connected with frame or engine mount.
Sounds u traced the problem.
#6 Re: Lighting error?!
- Jun 2013
- Leeds
12-24-2013, 06:25 PMHi all, lights now work when bike revved initially but the left indicators flash when pressed and come on constant with dipped beam and also the digital gear display flashes with the indicator!!
Help?!
#7 Re: Lighting error?!12-25-2013, 12:01 AM
Still sounds like an earth problem to me.
Are you sure the loose cable was an earth? If so, that you soldered it to real earth?
Only thing you can do in these cases is bring in some logical checking.
Check the main POS and NEG cables on the battery (no corrosion)
Check if the black earth cables connection on the engine or frame is clean and not corroded
Then move over to the effected area, and slowly work your way through all connectors.
Disconnect and connect them one-by-one (incl. the bulb fitting of each lighting bulb), then in small groups and see the results on all lights.
If you do this systemetacally, you will most likely find the culprit.
After that, you can check it is the bulb, the fitting, the conectors or a cable problem.
E.
#8 Re: Lighting error?!
- Jun 2013
- Leeds
04-06-2014, 09:58 PMIs it possible to create a separate wiring loom for the brake light?
Thinking power from battery to both brake switches and a cable spliced together for the rear brake light..... Would that work?
CFMoto ECU/ECM error code table & EFI error diagnosis
By bikerdoc in forum MaintenanceReplies: 8Last Post: 11-03-2019, 06:37 AM -
650Nk Error codes
By Wald0 in forum StreetReplies: 16Last Post: 07-30-2013, 03:16 AM -
Error code tables?
By wanglong in forum MaintenanceReplies: 3Last Post: 04-20-2011, 07:57 AM -
Adventures in lighting
By david3921 in forum Modifications (Cosmetic and Performance)Replies: 8Last Post: 11-12-2009, 11:47 PM
