Thread: Pulse adrenaline main jet
Results 1 to 2 of 2
#1 Pulse adrenaline main jet
- Jan 2014
- England, Merseyside
01-13-2014, 11:16 PMHi all,
I have recently bough a 105 main jet which I got because I have a Yoshimura end can on it and it pops alot!! In replace of the 95 get that was previously in it. Would I need to get a different pilot jet as well or can than stay the same? thanks
And does anyone know how to stop this popping if I wasn't to get a bigger main jet?
Also I have bought a 42mm air filter for it too.
Thanks TgL
#2 Re: Pulse adrenaline main jet
01-14-2014, 09:44 PMA bigger main jet is pretty essential if you have a cone filter and a performance exhaust since your engine will be running very lean (not enough fuel) which reduces power, causes the engine to run hotter and is probably causing the exhaust popping.
You probably don't need a bigger pilot as you can adjust the idle air-to-fuel ratio with the screw on the bottom of the carb, this screw is a pain to access because there is very little room to fit a tool in there, a bent hacksaw blade or a very short screw driver works. The way I adjust this is I set the idle speed to 2000 (with the screw on the right side of the carb), adjust the idle mixture screw to get the best idle speed (counter-clockwise makes it richer, clockwise makes it leaner), turn it clockwise 1/4 turn then adjust the idle speed back to 1500.Sinnis Max II (QM125-2V), K157FMI engine (technically a K162FMJ now), 115 main jet, 40 pilot jet, cone air filter, 150cc big bore kit, 17 tooth front sprocket, 30mm carburettor, alarm with remote start, HID spotlights, performance CDI.
superbyke rmr 125 Main jet question
By luke0085 in forum Modifications (Cosmetic and Performance)Replies: 3Last Post: 05-25-2013, 11:26 AM -
Sinnis Apache Main Jet
By scouse125 in forum Modifications (Cosmetic and Performance)Replies: 2Last Post: 10-31-2012, 06:49 PM -
Pulse Adrenaline 125
By extr3m in forum Modifications (Cosmetic and Performance)Replies: 1Last Post: 09-19-2012, 11:11 AM -
pulse adernaline 125 photo guide to main jet swap
By offtheclockuk in forum Modifications (Cosmetic and Performance)Replies: 15Last Post: 07-10-2011, 10:17 PM -
Pulse Adrenaline
By Rodders in forum Dirt n' Dual-SportReplies: 24Last Post: 02-01-2011, 04:47 PM
