#1 what is this came out my gs125 engine?
- Aug 2013
- wet wales
08-09-2014, 06:47 PM
please advise asap I am just getting it all put together today :(
#2 Re: what is this came out my gs125 engine?
#3 Re: what is this came out my gs125 engine?
- Aug 2013
- wet wales
#4 Re: what is this came out my gs125 engine?
- Aug 2014
- uk
08-22-2014, 10:43 PMUndo your sump plug, put the metal piece in first pointed bit up, flat bit at the bottom,
then the spring, then the sump plug, refill oil job done :)
#5 Re: what is this came out my gs125 engine?08-23-2014, 01:56 AM
#6 Re: what is this came out my gs125 engine?
- Aug 2014
- uk
08-23-2014, 03:42 PMI have just removed this exact spring and pin (neutral selector) from my sons pulse Adrenaline which i thought was mostly the same engine. so just to be sure, Check out this link guys.
http://www.100-biker.com/forums/showthread.php?t=44870
and
http://www.mychinamoto.com/forums/sh...125-oil-change
This is a pic of the SUZUKI DR125 GS125 Cam chain tensioner
Hope that helps..
#7 Re: what is this came out my gs125 engine?
- Aug 2013
- wet wales
08-23-2014, 04:29 PMdodgy is right not cam tensioner but I suspect they are bits to stop oil leaking everywhere when you try undo-ing sump nut
#8 Re: what is this came out my gs125 engine?09-13-2014, 10:32 AM
Hi, I had the same problem last Saturday...... I dropped the oil and this came out...I refitted it the way you have it in your picture...THIS IS THE WRONG WAY.... you will have problems finding neutral and may not light up neutral light. You need to put pin in first (narrow end) then the spring (on the flat end) then the plug.... seems f###ing silly way but it's wright..... just road-tested it and back to the way it was pre-oil change. hope this helps
just bought a gs125 engine for my adrenaline, need help with servicing
By impulsive in forum MaintenanceReplies: 6Last Post: 04-20-2014, 10:19 PM -
Which engine is it?
By dtracing in forum Industry News and Moto TalkReplies: 4Last Post: 02-06-2014, 01:15 PM -
kickstart on gs125 from qlink 200?
By impulsive in forum Modifications (Cosmetic and Performance)Replies: 7Last Post: 09-29-2013, 10:34 PM -
Re: just bought a gs125 engine for my adrenaline, need help with servicing
By hossman in forum MaintenanceReplies: 1Last Post: 08-20-2013, 08:34 PM -
Need new engine
By justas696661 in forum Dirt n' Dual-SportReplies: 10Last Post: 01-16-2011, 11:38 PM
