Results 1 to 5 of 5
  1. #1 Sinnis Apache 125 NEED A BIGBORE
    C-Moto Noob
    Feb 2018
    Germany, Rhineland Pfalz
    Hello Guys! I own a German Sinnis Apache 125, a SFM Sachs ZZ 125... is there a bigger bigborekit than the 150? im not afraid to split the case... i just want to go "crazy" since the sinnis has a bad reputation in Germany due to low power and poor reliability, and i want to prove them that they are wrong! Is there a way to get more than 15hp out of it? It doenst needs to be legal.
    My Sinnis already has well over 50k km on it too, i use it for touring and i love it.IMG_20171208_175559_438.jpg
  2. #2 Re: Sinnis Apache 125 NEED A BIGBORE
    Dec 2008
    There's 65.5mm kit in 'net. Quality varies btw seller cuz it's not as open source readily made 62mm kit
    This machinist https://shop68140890.taobao.com/ had made some solution
  3. #3 Re: Sinnis Apache 125 NEED A BIGBORE
    C-Moto Not-so-Noob
    Oct 2015
    bmth
    I know you wanted bigger than 150, but 150 is good on a bike this size for torque and rideability
    http://www.mychinamoto.com/forums/sh...haft-115mm-Jet
    I have modified a SFM125 Roadster with the same K157FMI engineer, there is also a link to the place to buy the kit - this s a 124cc labelled big fin for cooling. I have done 14,000KM on it and it is good. Key points..
    You will need to find an agent to ship the item below but it is worth it!!1
    http://world.taobao.com/item/1369688...?fromSite=main
    1. You can do it in a day - this is a straight swap
    2. Torque wrench required !!!
    3. Upjet to 115 worked for me
    4. Do not take all of the camshaft cover bolts off - 2 are for the rockers!
    5. If you drop the cam chain into the crankcase-this is easily retrieved with a tent peg - it is the camshaft c-ring you should watch
    6.Exhaust bolts - change for M8 and use two nuts on each for ease
    7.Donít forget to take the emissions connector off the barrel - it is two M6 bolts
    8.The camshaft tensioner should be removed -easy to reset the spring. -on the barrel
    9. Get 4 new Head bolts from CMPO (UK) as a precaution
    10. Get 4 new M8 nuts - 2 domed and two serrated flange for the head
    11. Remember to reconnect the Emissions pipe to your carb (comes from the vacuum unit near the front)
    12. Go for a 1:3 gearing ratio - eg 15 teeth front 45 back. This will rev out lower but given more torque and will hit 110KMH
    I also own a SFMZZ125 , I havenít modified it yet, but is slightly easier due to clearance.
  4. #4 Re: Sinnis Apache 125 NEED A BIGBORE
    Dec 2008
    Quote Originally Posted by dscheoff View Post
    ...[url]http://world.taobao.com/item/1369688...
    That seller seems the 1st made these kit available in chinese 'net. https://item.taobao.com/item.htm?id=531995601742 is ~40% off the above...
    Better rings https://item.taobao.com/item.htm?id=546681206119 ie. The good old [1.2/1.2/2.5] CG150 (those 1.0/ 0.8 is for newer genration piston)
  5. #5 Re: Sinnis Apache 125 NEED A BIGBORE
    C-Moto Noob
    Jul 2018
    Quote Originally Posted by humanbeing View Post
    https://item.taobao.com/item.htm?spm...id=37759962405
    Is this the correct kit? Also i know LT230S camshaft will fit the pulse adrenaline so i will upgrade that, Would this give me a displacement of 190cc? BLACK GS125 XIAO correct?
  1. Think I'm getting a Sinnis Apache..
    By Stevie1337 in forum Welcome to MCM!
    Last Post: 08-17-2014, 10:42 PM
  2. Sinnis apache mod
    By Bradleyrayner in forum Modifications (Cosmetic and Performance)
    Last Post: 07-02-2014, 09:50 PM
  3. sinnis apache
    By supersmooth315 in forum Parts Desk
    Last Post: 08-16-2013, 09:15 PM
  4. Sinnis Apache Main Jet
    By scouse125 in forum Modifications (Cosmetic and Performance)
    Last Post: 10-31-2012, 06:49 PM
  5. Sinnis Apache
    By JamieAldridge1 in forum Modifications (Cosmetic and Performance)
    Last Post: 09-27-2012, 07:17 AM
